RV.Net Open Roads Forum: Class A Motorhomes: UPDATE: Hard starting Cummins ISM
 > UPDATE: Hard starting Cummins ISM
Executive
Posted: 04/14/19 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Good Morning everyone! Cummins ISM. 95,000 miles. Just had it serviced, replaced water separator, filters etc. including Allison transmission service. Generally used Speedco for service but tried out a new facility in Arizona. My engine has always started within 3-5 seconds, I'll call it a short crank. After service it will still start but it now takes a long crank. That's the best way I can describe it. I'm not used to cranking an engine for an extended period of time. What could be the cause? It appears they used the correct water separator when it was changed Racor RK12963. Any insight will be appreciated....Dennis
* This post was edited 04/17/19 10:29am by Executive *
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
ppine
Northern Nevada
Posted: 04/14/19 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Try some additive for diesel to make sure you have gotten all the water out of the system. Many will add some cetane which makes for easier starting. They help take out some varnish in your engine.
JaxDad
Greater Toronto Area
Posted: 04/14/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Typically a longer crank to start after a service would indicate you still have some air in the system. Unusual on a newer diesel, but not unheard of.
How far / long have you driven it since the service was done?
Bird Freak
Dallas Ga.
Posted: 04/14/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like air in the fuel system. Maybe a bad seal on filter.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
grldst
Dallas, GA
Posted: 04/14/19 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Are you using the water separator with the clear bowl on the bottom? Some installers get confused as to proper installation of seals on these.
wildmanbaker
Kennewick, Washington
Posted: 04/14/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Contact the shop and voice you concerns after the service. There may be a small leak allowing air into the fuel line.
Wildmanbaker
Executive
Posted: 04/14/19 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone so far. You've verified my suspicions. Air somehow leaking back into the fuel was my initial thought. I've only driven it about 8 miles since the service..I;ll repurge the system today and see if that helps....Dennis
SidecarFlip
SE Michigan
Posted: 04/14/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
If it's a Racor, make sure the Tee handle is tight.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
11178adm
nw mo
Posted: 04/14/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
the most likely cause is the wrong engine mounted fuel filter. The cummins N14, M11 and ISM engine fuel filter must have a metal tube down the center of the filter or they will have long crank time. There are a lot of filters that will screw onto the cummins filter base but whatever they installed should cross to fleetgard number FS1000
JackMS
Gulfport
Posted: 04/15/19 09:24am Link  |  Quote  |  Print  |  Notify Moderator
If your separator is the type with the clear glass on top, there is usually an anti backflow valve in the outlet fitting. Very simple construction- a plastic cage with a ball and spring in it. Any bit of trash can cause a long crank situation, but it takes a while after shutting down to show up. If your engine is running and you shut it down and immediately restart, does it start better? If so then probably not that check valve.
2005 Holiday Rambler Neptune 34pdd, Cummins ISB 300, Allison 2500MH, Onan 8.0QD
Prior Toad-2001 Chevy 2500 CC 4WD
Toad-2012 Honda CRV, Blue Ox Aventa II
