RV.Net Open Roads Forum: Class A Motorhomes: UPDATE: Hard starting Cummins ISM
 > UPDATE: Hard starting Cummins ISM
Executive
Posted: 04/15/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
11178adm wrote:
the most likely cause is the wrong engine mounted fuel filter. The cummins N14, M11 and ISM engine fuel filter must have a metal tube down the center of the filter or they will have long crank time. There are a lot of filters that will screw onto the cummins filter base but whatever they installed should cross to fleetgard number FS1000
Thanks everyone again. After purging the system several times yesterday, I took the coach back to the shop this morning and advised them of the above and the other suggestions. They assured me they would fix it. I'm picking it up tomorrow and I'll post the results.
Thanks again for the sage advice....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Executive
Posted: 04/17/19 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Picked up the coach last night and it's fixed. When they put on the new filters one of the "O" rings didn't get seated correctly. Removed the filter, put on a new O ring and all is good again. Thanks everyone for your advice....Dennis
2 many 2
Posted: 04/17/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for coming back with the results, congrats on an easy fix! [emoticon]
wildmanbaker
Kennewick, Washington
Posted: 04/18/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Yes, thanks for getting back with the results. As you know, not everybody does. You are a valued member of this Forum.
Wildmanbaker
wildmanbaker
Posted: 04/18/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
And I still like the "Low Rider" picture of your MH in your sig.
Executive
Posted: 04/18/19 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Air leveling.
