RV.Net Open Roads Forum: Tow Vehicles: Timbren Question
Search only in Tow Vehicles
 > Timbren Question
Walaby
Georgia
Posted: 04/14/19 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Installing my Timbrens today. Put the assemblies together with the spacer. When the center bolt is tight, the spacer and rubber bump stop are "loose" kinda flopping a little.
Is this supposed to be like that? Both assemblies, with either short or long bolts (with and without spacers) don't tighten all the way up. So, Im assuming that's the way it's supposed to be.. Just seems kinda weird.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
djousma
SW Michigan
Posted: 04/14/19 09:32am Link  |  Quote  |  Print  |  Notify Moderator
They should not be loose. I'd contact timbren with your questions.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
Posted: 04/14/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Not normal. Need to be tight.
03 Arctic Fox 860
07 Dodge 2500 deezul
Walaby
Georgia
Posted: 04/14/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I should clarify.. Truck is 2017 Ram 3500. This application has the assembly bolting to a bracket, and bracket bolts to frame into OEM position, with OEM bolts.
I'll call Timbren tomorrow to check.
Thanks
Mike
Walaby
Georgia
Posted: 04/14/19 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Figured it out. Just had to get some leverage to really torque it down.
Mike
ACZL
UPstate,NY
Posted: 04/15/19 12:43am Link  |  Quote  |  Print  |  Notify Moderator
Mike
Spinach !!!
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Posted: 04/15/19 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Mmmmmkay...
Walaby
Georgia
Posted: 04/15/19 10:46am Link  |  Quote  |  Print  |  Notify Moderator
I was worried about stripping the threads and I had to add quite a bit of umph to tighten it. Shouldn't have been that way, but it worked. They are installed and all is good.
Mike
Posted: 04/15/19 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Mike
How loose was it? are you sure the nuts didn't bottom out on the shoulders of the bolts? Are they shouldered bolts?
Agree, this should not be the case.
 > Timbren Question
