RV.Net Open Roads Forum: Renogy 20/40 amp DC to DC battery charger
 > Renogy 20/40 amp DC to DC battery charger
grizzzman
salt lake city, Utah
Posted: 04/14/19 11:06am Link  |  Quote  |  Print  |  Notify Moderator
I just pulled the plug on a 40 amp unit. There Is a coupon for 20% off by giving them your email (the code is WELCOME10) At 179.99 for the 40 amp unit I could not pass it up! Look here
I will be using it as a backup charging source. With my solar I have not needed a alternate source as of yet, but I believe the day will come.
* This post was edited 04/14/19 04:55pm by grizzzman *
2013 Ford F150 EcoBoost SuperCrew BFG KO2 10 Ply
2016 Rockwood Mini Lite 2504S. TM2030. SC2030 , Grape solar BT 40 Amp PWM
640 Watts Solar. Costco CG2 208 AH and Group 31 192 AH Batteries
400 Watt and 2000 Watt Inverter's hard wired.
Boondocking is my Deal
2oldman
New Mexico
Posted: 04/14/19 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Your link isn't working because you've included 'have a look' at the front of the url.
Have a look
landyacht318
Near a large body of salty water
Posted: 04/14/19 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
Seems like a good solution to vehicles that only allow mid to high 13v when the house batteries are still depleted. I don't really like the 40 amp limit but 40 amps seeking mid 14's is better than a vehicles voltage regulator saying 13.7v is fine and dandy for those depleted batteries.
grizzzman
Posted: 04/14/19 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Have a look
Thanks!
landyacht318
Posted: 04/15/19 12:36am Link  |  Quote  |  Print  |  Notify Moderator
The Illustrated wiring diagram shows they want to pull both + and - from engine battery, instead of takng the + right from the alternator.
The latter is usually a shorter circuit which bypasses the 'just thick enough' stock wiring from alternator to engine battery and without a DC to DC device in the middle, will deliver more voltage and thus more amperage to depleted house batteries.
This 'just thick enough' stock wiring will now be asked to pass those 40 more amps when the renogy DC to DC charger is seeking 14.7v on a depleted house battery.
Might want to add more copper in parallel to the 'just thick enough' OEM wiring from alternator (+) stud to engine battery (+), properly fused of course. Also upgrading the ground wire from engine battery to engine block could be considered wise insurance.
Since it is taking whatever voltage the engine battery is at, and stepping it upto the 14.7, well the renogy unit will not generate as much heat stepping up 13.6 to 14.7 as it would stepping up 13.2 to 13.7v. it might add longevity to the unit to reduce the amount of voltage stepping it has to do by lessing voltage drop on the 'just thick enough' stock alternator to engine battery wiring that the beancounters insisted was adequate.
