RV.Net Open Roads Forum: DC inline fuse blows when battery power turned on
 > DC inline fuse blows when battery power turned on
baseball
Georgia
Posted: 04/14/19 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 Fun Finder with a DC power issue. I just replaced the battery because the dealer put a bad battery on the trailer. Anyway, when I go to turn on the DC power to trailer, it blows the inline 30 amp fuse. it is located on the negative side of battery. I have a plunger type switch to turn on/off DC power to cabin. the shore power works fine, but not sure it is recharging the battery. Any ideas on where to start will be appreicated. If you need more info to diagnose the problem, let me know.
Ernie
Chris Bryant
Arden, North Carolina
Posted: 04/14/19 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
If it just started when you replaced the battery, odds are you hooked it up wrong.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Toddupton
Michigan
Posted: 04/14/19 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure that is a negative cable? Not sure why there would be a fuse there except maybe reverse polarity protection but have never seen it done that way. Trace the wire to the frame and make sure positive and negative are correct.
SoundGuy
S Ontario
Posted: 04/14/19 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
It's not a fuse but a circuit breaker, usually auto resetting, and it should be in the positive cable coming from the battery. Sure sounds like you've connected the battery backwards.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
time2roll
Fuse is typically on a heavy black wire to the positive battery terminal.
Main negative connection is usually white and connects to the frame.
675w Solar pictures back up
baseball
Georgia
Posted: 04/14/19 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
thanks Chris. i swapped them and now no blown fuse, but still no power to cabin. I went to fuse box and checked the two 30a fuses located at top of what i will call the DC distribution panel. no issues. the negative from battery connects to top left terminal on panel. the positive comes in and leaves on white wire from battery on top right. Right beside it is a red wire which the panel says is the positive from converter. when i put meter on the white and black terminals, there was not power. Could this be a bad converter??
time2roll
Posted: 04/14/19 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
Check the converter is getting 120vac in and should produce 13.5 vdc out.
Although if the battery is charged you should have 12.5+ volts in the DC fuse panel.
baseball
Georgia
Posted: 04/14/19 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
ok. more info. i do not have any shore power to trailer. and the white negative is not connected to frame. it goes into a cover in the passthur space at from of cabin. taking cover off, there multiple wires connected via wire nut to the negative. if it is connected to frame, it must be somewhere back towards the rear. there is nothing close to the tongue.
BFL13
Victoria, BC
Posted: 04/14/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
"the positive comes in and leaves on white wire from battery on top right."
White is negative!
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
garym114
Bluff Dale, Texas
Posted: 04/14/19 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Get a multimeter and check which is positive and which is negative all the way through so you will know. Makes no difference what the wire color is.
