RV.Net Open Roads Forum: Tech Issues: Water heater circuit board
 > Water heater circuit board
Knoffsinger
Virgin. Utah
Posted: 04/14/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
We are in a 2000 Komfort fifth wheel and our water heater quit working today out of the blue. The breaker was flipped and we flipped it back but the hot water is still not working. We noticed that the circuit board (35-525900-113) looks possibly fried. We've only used it on electric, not on gas. A few of the diodes also are loose or falling off. Is the circuit board only for when your on gas? Is there somewhere we can buy another circuit board? Is there anything else we can try before going out and buying a new water heater? We are in our fifth wheel full time so it's super important for us to fix this ASAP.
enblethen
Moses Lake, WA
Posted: 04/14/19 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Make and model of water heater?
Breaker is for 120 volt option if equipped.
Needs 12 volts DC on most to operate.
Quick search shows you have a Suburban. Circuit board is easily available from Dinosaur electronics via Amazon.
Circuit board
Dinosaur Electronics
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Old-Biscuit
Verde Valley
Posted: 04/14/19 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Suburban Water Heaters use 'separate' systems for electric and propane.
Circuit Board controls propane ONLY (except for DEL models)
Electric system
120V AC Circuit breaker AC Junction Box on backside of WH TANK (right side looking from the back)
From Junction Box to on/off switch (OEM in outside compartment lower left corner)
From On/Off switch to Hi temp t-stat to normal temp t-stat (under cover above gas valve---Hi temp is resettable Left 'Push to Reset' button)
From t-stat to element (under cover below/behind gas valve)
120V AC Circuit Breaker tripping...element most likely shorted/burnt out.
Break out voltmeter and trace the 120V AC circuit to Junction Box ---to element
Do a continuity test on element
Disconnect the wires (Black/White from element)
Check for continuity between the Black & White element terminals
No Continuity...element bad
Check for continuity between White terminal and element flange
Got continuity...element shorted
New elements available at most any 'big box' hardware store
120V AC 1440W element
Wherever I happen to park
Posted: 04/15/19 05:05am Link  |  Quote  |  Print  |  Notify Moderator
Circuit board
I second the Dinosaurelectroics link..
When my Water heater needed a new board I did not have the time to order so I went with an OEM
But for my furnace I went with Dino boards.. I'm a trained electronics tech and the first thing I noticed was the QUALITY of the board.. (Way better than OEM) the next was.
Well as an electronic Tech I have a theory as to what killed the OEM board.. Turns out Dino shares that theory because they put a protective device on the board to prevent it from happening again.
Home is where I park it.
Old-Biscuit
Verde Valley
Posted: 04/15/19 11:55am Link  |  Quote  |  Print  |  Notify Moderator
OP might need a new circuit board .....for propane usage
NOT for the electric element use
