RV.Net Open Roads Forum: Class A Motorhomes: Engine batteries not charging
 > Engine batteries not charging
jaycocamper62301
Illinois
Posted: 04/14/19 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have my 2006 Bounder 37U here at home in my shop and has been hooked up to shore power since Wednesday. House batteries are charging and chassis batteries are not. Now the RV won't start. Where do I start. I have a Big Boy battery isolator ad it has 13.4 volts on one post and 11.5 on the other. All interstate batteries are 2 years old
enblethen
Moses Lake, WA
Posted: 04/14/19 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a "aux" start button on the dash? It is a momemtary rocker. Pushing it should allow to start the rig off the coach batteries.
Many rigs do not charge the chassis battery from shore power. I put a small charger on the chassis battery to keep it up.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
jaycocamper62301
Illinois
Posted: 04/14/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
Aux switch did not help the starter one bit
enblethen
Moses Lake, WA
Posted: 04/14/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Did you hear a load click when you pressed the switch? No, would mean no power to it. Locate your battery control center and check for the aux start fuse.
The aux start relay on many are the same one for charging coach battery from the chassis alternator.
RLS7201
Posted: 04/14/19 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Close to the two battery banks is a black box called a Battery Control Center (BCC), manufactured by RV Custom Products. In the BCC, behind the circuit board, is the isolator relay. It's the silver one. It's probably your problem. On the back side of the BCC cover is a wiring print, that shows how the isolator relay connects the two battery banks together when either battery bank reaches 13.2 volts. Your coach DOES charge the chassis battery when plugged in. Advice about your charging system from non Fleetwood owners is usually incorrect.
Richard
If I had a dollar for every girl that found me unattractive,
they would eventually, find me attractive.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
jaycocamper62301
Illinois
Posted: 04/14/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
yes i remember see that exact box you described
enblethen
Moses Lake, WA
Posted: 04/14/19 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
The cover should show the fuses and their function.
jaycocamper62301
Illinois
Posted: 04/14/19 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
Richard
so you're saying take the entire fuse panel out because there is no isolator relay there
jaycocamper62301
Illinois
Posted: 04/14/19 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
the cover explains nothing
pianotuna
Regina, SK, Canada
Posted: 04/14/19 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
I would jumper around the isolator device. That may help to trouble shoot where the problem is.
Regards, Don
