RV.Net Open Roads Forum: Fifth-Wheels: Gen hook LM SAVANAAH
 > Gen hook LM SAVANAAH
alboy
Kelowna B.C.
Posted: 04/14/19 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
ALready have the gen prep and want to hook up our eu 3000 IS to it.It has a junction box in the front compartment that you attach your gen then it goes to a transfer switch.SO attaching the hot do i need too legs of 120 or will one work? I could jump from one hot leg to the other so would have 2 hot 120?I understand there is a yellow stopper that has to be removed from the transfer switch prior to activation.
THANKS AL
eHoefler
ozark mountains
Posted: 04/15/19 05:50am Link  |  Quote  |  Print  |  Notify Moderator
Connect the 2 hots together to gen hot, nuetral to nuetral, ground to ground
2014 Ram Laramie, 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
