RV.Net Open Roads Forum: Fifth-Wheels: Furrion vision s problem
 > Furrion vision s problem
Jimbee
New York
Posted: 04/15/19 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Hey All,
I'm having an issue with the Furrion 4.3 observation camera I just purchased. The manufacturer claims the camera will work at distances over 250 feet away. When I turn on the camera it works for about 5 seconds then says "no signal". Even when the camera and monitor are only an arms length away without any obstruction it drops the signal. Before I send the camera back I thought I'd ask Y'all if perhaps there is a setup procedure I'm missing. I've tried different antenna angles, etc... and nothing seems to help. Is it just a defective unit and should I try a replacement? Is this a common problem with wireless cameras?
Thanks!
DarkSkySeeker
Freestone, California
Posted: 04/15/19 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I think it is a common problem with electronics. "DOA" - dead on arrival. When I look at the ratings for a lot of products, and particularly electronics, the one star ratings are often "DOA".
There is something special about camping in an RV.
2Rad4U
I'm to young to be a
Posted: 04/15/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
1 800 789 3341
Give Furrion a call. They have a great support staff.
Chris
2019 Rockwood 2608BS
2018 Chevy 2500HD
rbp111
Citrus Heights, CA
Posted: 04/15/19 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
Did you "pair" the camera to the monitor?
Jimbee
New York
Posted: 04/16/19 05:39am Link  |  Quote  |  Print  |  Notify Moderator
I sent the camera back and re-ordered a replacement. After several re-pairing attempts from just a couple feet away I decided it had to be a defective unit. Especially after reading all the good reviews from others with the same camera.
Should be here by the end of the day!
Thanks!
sgfrye
north carolina
Posted: 04/17/19 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
Hope all is well with replacement camera. i have had the camera on 2 Travel trailers. Current TT is 37ft long. Have had no issues with signal. Very happy with it.
