RV.Net Open Roads Forum: Technology Corner: Any DIY dish mounts?
 > Any DIY dish mounts?
Super_Dave
Harrisville, UT
Posted: 04/15/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I've never liked the flimsy little tripods and wondered if anyone designed their own simple but effective dish mount. (Looking for ground mount).
TIA.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Tom_M
New Hope, MN
Posted: 04/15/19 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
A friend of mine uses a setup like the following:
http://rvroadtrip.us/library/dishstand.php
Tom
2005 Born Free 24RB
Towing 2013 Smart Car
VoodooMedicineMan
Illinois
Posted: 04/15/19 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
I use a roof mount tripod antenna and screw it to the ground with lag screws.
Bill and Joey the dog
Johno02
Lexington, TN USA
Posted: 04/15/19 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I made my own, which served very well for a number of years. Sadly, all the pictures have been deletedbut if you will PM me, I will tell you how to make one very cheaply. Also, I have seen ones made from Plastic pipe that are very compact, lightweight, and easy to travel and store. Most are made to use the dish inverted, laying on its back, which makes it very stable. Like said, PM me for instructions on how to make one very cheaply.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
Big Katuna
Deland, FL
Posted: 04/15/19 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
I used to use one like this when I used Directv SD. Leveling wasn’t important for that dish.
When HD took over, I switched to a surveyors tripod and made a mount.
Rock solid, easy to level and light.
My Kharma ran over my Dogma.
Super_Dave
Harrisville, UT
Posted: 04/15/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Is a bucket of concrete stable enough in wind? The dish will be a DirectTV HD Slim Line. Wind has been my biggest concern with any design.
Big Katuna
Deland, FL
Posted: 04/15/19 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
The surveyors tripod has pointed feet with a foot step which lets you push it an inch or two into the ground. I never had it blow over.
Remember the legs are long so the feet are feet apart. Very stable.
A bucket of water or a few plastic bottles of water would be plenty.
I used it with a Slimline.
I switched to DISH with an auto align Winegard Pathway.
Dutch_12078
Winters south, summers north
Posted: 04/15/19 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
I've used our modified $25 tripod for almost 10 years with no stability problems just using a half full 5 gallon pail for ballast. The photo below shows our setup right now that withstood up to 50 MPH wind gusts today in Virginia.
Dutch
2001 GBM Landau 34' Class A
myredracer
Langley B.C.
Posted: 04/15/19 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
I've learned the hard way you need to make sure the wind won't flip the dish over. Can't always drive stakes into the ground so I bought a base for a patio umbrella but doesn't hold quite enough water to help much.
I wish there was something more elegant than using a 5 gallon pail or heavy concrete blocks. The idea of the inverted dish closer to the ground is a good idea.
Making a clamp that attaches to a picnic table is about the only other option I can think of. Except that sometimes CG picnic tables are old and rotten and/or wobbly.
I hate CAPTCHA. It just will not go away...
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2012 GMC Sierra 2500HD crew cab
wxtoad
Sturbridge MA
Posted: 05/05/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I made this simple mount using PVC pipe. Comes apart for storage and takes up very little space. Amazingly quick and easy to set up. It's very stable on uneven ground and in high winds.
2005 Lazy Daze 26.5 Rear Bath
NE13
