RV.Net Open Roads Forum: Tech Issues: 30A to 40A trailer fuse
 > 30A to 40A trailer fuse
esfd243
East Syracuse, NY
Posted: 04/15/19 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Our TV is 2012 2500HD D/A. We at times lose our refrigerator while driving. It runs off an invertor instead or propane. I have found that the 30A 12v fuse under the hood is blown. Online shows that its a MAX 40A fuse. Can I just change it out? I am not an electrical person.
Mike, Dawn & Mallori
2016 Hemisphere 368RLBH
2012 Chevy 2500 HD D/A 3.73
2oldman
New Mexico
Posted: 04/15/19 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure I understand. Is this fuse for the wire supplying the trailer with power to charge batteries?
BFL13
Victoria, BC
Posted: 04/15/19 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Ours came with a 40a fuse in Stud 1, but IMO that is not the problem. Never saw more than about 20a using the 7-pin, but had problems at times back at the 7-pin bumper end with corrosion shorts etc. A short back there or with the trailer's end of it is more likely to blow that fuse IMO.
The inverter should be on the house batteries with good fat wiring and get its amps for the fridge from that. The 7-pin just helps a bit.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Wherever I happen to park
Posted: 04/15/19 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Reason #2 why I have an RV type Absorption Fridge
THe fuse is there to protect the wire IF you put in a BIGGER fuse the wire can overheat and .. FLAME ON.. You do not want this happening.
Home is where I park it.
KD4UPL
Swoope, VA
Posted: 04/15/19 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
You can change it to a 40A if that is what GM designed it for. It's possible someone previously swapped the 40A for a 30A because it was easier to find. I would look in the truck's owner's manual and see what size is supposed to be there. If it says 40, fine, put in a 40. If it says 30 then leave it alone.
I'm not surprised it's blowing. 30 amps is only about 360 watts. Your refrigerator likely pulls a good bit more than that. I would have thought the long run of small wire in the truck and trailer would have limited the current but maybe not.
Or, you could have an intermittent short in the wiring somewhere.
If you get a clamp-on amp meter that reads DC you can measure the current flow with the refrigerator running.
I take it you have a residential electric refrigerator? If your ref. will run on propane I'd just run it that way since trying to run it on 12v is pushing the limits of the circuit.
Lantley
Ellicott City, Maryland
Posted: 04/15/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
If I understand you correctly your truck has a 30 amp fuse however the manual/specs. call for it to be a 40 amp fuse? Are you the original owner of the truck?
If the fuse has been changed from the factory spec of 40 amp to a 30 amp I would certainly change it back to a 40 amp.
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
time2roll
Posted: 04/15/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
If the owners manual says that slot takes a 40 amp fuse then by all means put in a 40 amp fuse.
675w Solar pictures back up
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 04/15/19 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
You can also use a cartridge fuse referred to as a 'slow-blow' Instead of having clear glass slow blow fuse centers are white. Gives you the accurate protection of 30-amp fusing but will withstand the extra amperage that a compressor uses for start up.
Always fuse a general feed circuit for the wire amp capacity. Fuse branch circuits for the load. Fuses for anything electronic and circuit breakers for anything else.
Charlie D.
E. Texas-Orange
Posted: 04/15/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Every fuse location on my 2007,2013 and 2018 had the fuse amperage at the installation point.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
2oldman
New Mexico
Posted: 04/17/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
op is gone
