RV.Net Open Roads Forum: Fifth-Wheels: Hitch longevity
 > Hitch longevity
RobWNY
Jamestown, NY
Posted: 04/17/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
RobWNY wrote:
I don't know if my choices of lubricants are right or wrong but I use Blaster White Lithium Grease on the jaws and pivot points before each use and I have a grease zerk fitting on the underside of my B&W that gets some Red N Tacky grease once a season. On the pin I use a Lube Plate. It keeps things from getting messy because I don't have to grease the plate itself
Overkill on the pivot points and under kill on the supporting shaft with the grease ZERK.
To clarify...I only grease the support shaft zerk once a year because B&W recommends once every six months for the amount of use my hitch gets. Here in the Northeast, 6 months is all we get for camping so it is a once a year deal for me. I lube the polyurethane bushings every time because they are always dry when I check them. You're probably right about the jaws though. I just spray the lithium grease because it's already in my hand after doing the bushings.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
Bird Freak
Dallas Ga.
Posted: 04/17/19 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
My class 8 truck had over a million miles on it when sold. Just kept hitch clean and lubed well.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
valhalla360
No paticular place.
Posted: 04/18/19 12:41am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
"Sure wish they'd come up with a "lube tube" for king pins; d@mn grease gets messy."
Not sure it's that big of a deal...you don't need a ton of grease on the pin itself and really only on the wear surface. If you have globules of grease hanging off the bottom, that's more than you need.
Honestly, seems to do more to keep rust away than out of any significant lubrication need.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Cummins12V98
on the road
Posted: 04/18/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
For fun remove the shaft from the head on the B&W. If you do so you will see it needs to be greased more often than not!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Arizona
Posted: 04/18/19 11:22am Link  |  Quote  |  Print  |  Notify Moderator
The only issue I've seen with a B&W hitch was one where the owner left it in is truck, for years, without the head in place. The poly pads on the side pieces were just rounded knobs because they'd been sun-rotted so badly. I can't think how long that must've taken. Sad...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
RobWNY
Jamestown, NY
Posted: 04/18/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Because you got me thinking I should lube it more often, I did that today. It took 6 grease gun "squeezes" before grease came out on the end at the nut. So thank you! It can't hurt to grease more than I need to but it sure can cause problems by not greasing enough! In my case, I was ok but I did add more than I thought it would take. For what it's worth, I talked with a B&W tech about the grease they use when manufacturing their hitches. He told me they use a Mobil Blue Lithium grease at the factory. I wanted to make sure my Red n Tacky Lithium was compatible before putting it in. I wonder how many people use a non compatible grease because they either don't know you shouldn't do that or they don't know what kind of grease the manufacturer used and they just wing it.
Cummins12V98
on the road
Posted: 04/18/19 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
I think most don’t know there is a ZERK under the head.
RobWNY
Jamestown, NY
Posted: 04/19/19 08:18am Link  |  Quote  |  Print  |  Notify Moderator
You're probably right.
ford truck guy
Pennsylvania
Posted: 04/19/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
just like MOST didn't/don't know there are 9 zerks on the Tri-Glide...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Cummins12V98
on the road
Posted: 04/19/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
EXACTLY!!!
Maybe mine has lasted full timing hauling 23-25k for nearly 4 years cuz I grease ALL 9.
 > Hitch longevity
