RV.Net Open Roads Forum: General RVing Issues: tpms vs tire gauge reading
 > tpms vs tire gauge reading
rbp111
Citrus Heights, CA
Posted: 04/16/19 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased two things for the trailer. One was a tire gauge and the other was the Tire Pressure Monitor System.
First, I checked the pressure by use of the gauge (brand new). The tire pressure showed 110 PSI. After that, I installed a TPMS and noted that the Tire pressure was showing 115 psi (cold pressure). As the tire is used and the day increases in heat, the tire was showing 123 psi.
what PSI should I follow? The first gauge that shows the psi to be 110 or the tpms which shows the pressure to be 115. Or should I decrease the amount of air, putting the tpms as priority, in other words putting the psi to 110 down from the reading of 115?
Cummins12V98
on the road
Posted: 04/16/19 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
All depends on the QUALITY of each item there is a lot of junk out there.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fj12ryder
Platte City, MO
Posted: 04/16/19 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, just depends on which is the better quality. My pressure gauges and my TPMS agree to the pound.
Howard and Peggy
"Don't Panic"
Ava
Vancouver Island. BC Canada
Posted: 04/16/19 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
My TPMS monitor is adjustable to set pressure close to a regular gauge.
Posted: 04/16/19 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Split the difference. 2.5 psi either way makes zero difference.
JimK-NY
NY
Posted: 04/17/19 05:11am Link  |  Quote  |  Print  |  Notify Moderator
My Ram TPMS readings match my manual gauge exactly and that is true for my 2018 truck and formerly for my 2010. I would get a new gauge and recheck.
bucky
Raleigh metro
Posted: 04/17/19 05:38am Link  |  Quote  |  Print  |  Notify Moderator
You can buy 5 of the same exact gage or tpms sensor and get 5 different answers. Drives me crazy.
2005 Cummins 2500 2WD LB quad cab pulling a 2014 Blue Ridge 3025RL
Sam Spade
North Central Florida
Posted: 04/17/19 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Try another gauge.
But I think you will find that the gauge is "right" and the TPMS is off a bit.......or off more than the gauge.
TPMS sensors are really not intended to be used to "air up" the tires but to monitor them for pressure LOSS as you go down the road.
+- 5 PSI cold usually isn't a big deal.....and the pressure ALWAYS will go up as the tires heat up.
Once you get a feel for the calibration errors in the TPMS system, which can be different for each sensor, then you will know what readings are "normal".
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
IdaD
Idaho
Yeah as long as you're not way off it doesn't really matter. Tire pressures vary quite a bit from cold to rolling down the highway on a hot day, more than a couple of PSI.
2015 Cummins Ram 4wd CC/SB
Bobbo
Wherever I park
Posted: 04/17/19 08:11am Link  |  Quote  |  Print  |  Notify Moderator
My TPMS consistently reads 2 psi lower than my gauge. When reading the TPMS values, I just add 2 psi.
Bobbo and Lin
