RV.Net Open Roads Forum: General RVing Issues: tpms vs tire gauge reading
 > tpms vs tire gauge reading
JKJavelin
Milwaukee, WI
Posted: 04/17/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
What matters most in a TPMS is consistency and its ability to see the pressure drop is its main job. Use a good quality gauge for cold air pressure. When going down the road, watch for fairly consistent pressures and temperatures occasionally. The actual pressure itself on the TPMS is secondary as long as all tire readings are close to each other.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 59 Nights
jkwilson
Indiana
Posted: 04/17/19 10:29am Link  |  Quote  |  Print  |  Notify Moderator
JK
Agree 100%. As an engineer, I was always concerned with accuracy, but in a lot of cases, repeatability is far more important and much, much less costly.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Route 66 Traveler
Western Arizona
Posted: 04/17/19 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
I use a quality tire gauge to set all of my trailer tires to the same cold pressure, then monitor them with my TPMS system. Usually they are within a few pounds of the set pressures, unless they have been sitting in the sun for awhile. Once on the road the pressures vary from tire to tire just a bit, but never more than 3-5 pounds.
wilber1
Abbotsford B.C.
Posted: 04/17/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
JK
I agree. I set the pressures with a gauge and rely on the TPMS to let me know if there is a big change. Pressures when running will change according ambient temperature, to how much weight a tire is carrying, which side of the rig is facing the sun etc.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
rbp111
Citrus Heights, CA
Posted: 04/18/19 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input. I guess the TPMS is doing what it is supposed to be doing, i.e. note a change in tire pressure.
I guess I will leave it alone.
