RV.Net Open Roads Forum: Class A Motorhomes: sparkplugs and wires
 > sparkplugs and wires
MrWizard
Traveling
Posted: 04/17/19 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
i know this is subjective
best sparkplugs and plug wires
1997 Ford 460"
its time to replace them, running rough even a few backfires
Radiate The Happy
1997 F53 Bounder 36s
John&Joey
Summer-North,Winter-South
Posted: 04/17/19 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Can’t lose with NGK. Wires your call, but keep high heat in mind. Might even invest in heat socks for the ends.
path1
Varies with weather
Posted: 04/17/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Over the years of owning Fords I've learned to stick with Motorcraft, OEM regardless if it's alternator's, water Pumps, coil over plugs, or whatever
K Charles
Connecticut
Posted: 04/17/19 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Motorcraft here too.
RLS7201
Posted: 04/17/19 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Autolite AP25 Platinum is OEM. Probably out last the coach.
If I had a dollar for every girl that found me unattractive,
they would eventually, find me attractive.
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
garyemunson
Reno, Nevada
Posted: 04/17/19 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
I've never been disappointed by Motorcraft parts. The originals last a long time and the vehicle is falling apart before the replacements go bad...
ArchHoagland
Clovis, CA, USA
Posted: 04/17/19 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
When it comes to vehicle electric items I've found OEM is the best.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
wildmanbaker
Kennewick, Washington
Posted: 04/18/19 09:51am Link  |  Quote  |  Print  |  Notify Moderator
MSW (Magnetic Suppression Wiring) wiring and Bosh fine wire platinum plugs, longevity and performance.
Wildmanbaker
twodownzero
NM
Posted: 04/18/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I concur completely. AC Delco for GM, Motorcraft for Ford. Every time.
MrWizard
Traveling
Posted: 04/18/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
my autozone did not have the motorcraft sparkplugs in stock
but i did get a set of Autolite XP25 Iridium plugs
thanks for all the help
