RV.Net Open Roads Forum: Travel Trailers: Extension Cord
 > Extension Cord
Page of 5
kearlms
Rexburg, ID
Posted: 04/18/19 10:27am Link  |  Quote  |  Print  |  Notify Moderator
We have found ourselves in a spot where we are going to have to live in our camper for a bit and need to purchase an extension cord that will reach the closest power. I am looking at a heavy duty 100 ft 12 gauge extension cord. I will only be plugging into a 15 amp plug for the time and it is about 100 ft from the trailer. We wont be using the A/C and will only be using lights, TV, and heater when needed. So, my question is will this be good enough for us?
Ava
Vancouver Island. BC Canada
Posted: 04/18/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
I think that would work fine. I found a 100 ft 12ga. cord at Costco for a good price.
time2roll
Posted: 04/18/19 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Good to go. Worst case the breaker will trip and you will need to adjust the load in the RV or discover the shared load at the source.
675w Solar pictures back up
enblethen
Moses Lake, WA
Posted: 04/18/19 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Even though you pan on using minimal power except for a heater and especially because of the heater, I would suggest using a 10 gauge extension cord. Be prepared for connector and trailer 15/30 adapter failure on any cord you decide on. I would be prepared with a 30TT female connector to replace the standard 15 amp cord body for the trailer end of cord.
another option is to get 10/2 with ground UF cable instead of an extension cord. Build your own "cord" with it.
10/3 100foot extension cord
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Boomerweps
Hills of PA
Posted: 04/18/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Wow, that 100' 10AWG extension cable is costly! But it would cut your voltage loss some.
I measured 107.7VAC on my EMS at 110' of 12AWG from my breaker box to the TT. Starting voltage, no load 122VAC. This was with just the AirCon on and converter, all else turned off. Pulled 12.9 amps.
Added in the fridge and it read 104.5VAC pulling a total of 15.8 amps.
I installed a Progressive Industries EMS 30 but used a Kil-A-Watt meter prior. The Kil-A-Watt cost about $25 at Harbor Freight. It's good to know how much power your RV gear pulls. In volts, watts, & amps.
Bottom line, keep your cables as big and as short as possible and what you can afford.
Www.calculator.net voltage drop calculator. Plug in your wire length, AWG, starting voltage, and amp load and it will tell you expected voltage loss. Very accurate. Most electrical and electronics are designed run no lower than 105VAC.
You'll need to educate yourself and others on what can be turned on at the same time given your power source. With 100' 12AWG extension cord, no microwave with AirCon OR electric space heater. Or any electric heated cooking device including coffee maker, toaster, frypan, etc. One of those at a time!
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
Boomerweps
Hills of PA
Posted: 04/18/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Just for a sample of power use per item in my TT:
Fridge 2.733 amps
BR fan .33 amps
Microwave 10.25 amps
AirCon 12.05 amps
Converter at idle .117 amps
Water heater 10.38 amps
Toaster 5.77 amps
Space heater 1500 watt 12.5 amps
Electric griddle 12.5 amps
Single serve coffee maker 6.67 amps
Granted, not all TT have the same appliances but this will give you an idea. Hopefully, the receptical and circuit you are plugging into is 20 amp vice 15. IF the supply line is all 12AWG to the receptical it can use a 20 amp circuit breaker per NEC.
Seperate issue. If you are going to be in the TT for an extended time, look into getting a 100# propane tank. Depending on your heating and cooking choices.
What about water and sewer in your situation?
pianotuna
Regina, SK, Canada
Posted: 04/18/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Don't buy a premade cord. Go to an electrical wholesaler and purchase 100 feet of #10-3. Get the type rated for cold weather and UV resistant.
Regards, Don
kearlms
Rexburg, ID
Posted: 04/18/19 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
So all we will be running is Fridge on propane, Furnace, TV, Bathroom fan as needed, Water pump, and charging phones as needed. Not using a lot of power. Stove we will use, but that is propane. Microwave may or may not be used, but if it does it will only be if necessary. Wife does not like microwaves very much. WE have plenty of water, spigot within 10 feet. Sewer we will have to pull out and dump, but we will have an indoor bathroom for our use.
352
Oxfofd, Fl
Posted: 04/18/19 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
What he said
Facebook/The manatees of Halls river.Sam and Gail Oxford Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
time2roll
Posted: 04/18/19 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
You will be using maybe 2 amps most of the time. Maybe 4 if you put every light on while using the pump and fan to shower. Standard microwave will pull a solid 12 amps alone. Maybe less for a small unit. Divide cooking wattage by 10 or read the nameplate at the cord entry.
100' #12 is fine for all this.
Page of 5
 > Extension Cord
