RV.Net Open Roads Forum: Travel Trailers: Slide out stuck?
 > Slide out stuck?
camsa5
Too young to be a
Posted: 04/18/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I have a trailer with 3 slide outs. Living room and 2 slide outs in the back for the kids room. The living room and one bedroom slide works fine. The other bedroom slide will not open. When I press the open switch I hear alot of clicking but it will not move. Is there a way to push the slide out manually? They are electric slides. Help please.
- 2013 Skyline Layton Joey 310 - (six bunks,3 slides)
- 2007 Coachmen Clipper 1272ST - (Pop-Up)
LoudRam
Southern NJ
Posted: 04/18/19 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Usually there is a manual crank under the trailer. But climb under and see if you can tell what the problem is before you manually open it. Also look around the slide on the inside to see if anything got wedged in the slide path.
Todd
Desert Storm Vet (US Navy)
2019 Ram 1500 Classic Quad Cab Express 4X4 5.7 Hemi 3.92
2018 Dutchmen Aspen Trail 2880RKS
If you can read this thank a teacher
If you can read this in english thank a vet
schlep1967
Harrisburg, PA
Posted: 04/19/19 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Looking at your floor plan, I would first check to make sure those cabinet doors on the back wall are closed. If one of them came open in travel it could be keeping the slide from opening.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
CaLBaR
Ontario, Canada
Posted: 04/19/19 06:02am Link  |  Quote  |  Print  |  Notify Moderator
I agree with the others. The clicking is the clutch ratcheting because the slide won't move. Very likely something like a cabinet door or something has jammed it.
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
IB853347201
Eastern Ontario
Posted: 04/19/19 07:47am Link  |  Quote  |  Print  |  Notify Moderator
On the other hand the clicking could be an indication of low 12 volt voltage.
Being a 2013 trailer, i suspect that your battery is toast unless you have recently replaced it?
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
schlep1967
Harrisburg, PA
Posted: 04/19/19 08:02am Link  |  Quote  |  Print  |  Notify Moderator
The other slides work. This indicates an issue related to the one that doesn't.
camsa5
Too young to be a
Posted: 04/20/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for chiming in. Voltage is at the proper 12V at all motors. I'm thinking it mat be stuck. I just have to find how it is stuck. I might try the manual overide to see if it comes out.
fdwt994
Indianapolis, IN
Posted: 04/26/19 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Any luck?
2018 F250 6.2 Crew Cab
2018 Salem Hemisphere GLX 312QBUD
A family who loves to camp!
Bears Den
Estero, Fl.
Posted: 04/27/19 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Mine has solenoids on the front A frame between the battery and the body of the trailer. That happened to me once and I had a loose connection at the solenoid. Tightened the connection and it’s worked fine since.
2014 Kodiak 279 rbsl
2017 Ford F-150 King Ranch V8
Equalizer hitch
Ford integrated brake controller
2004 Travel Lite 23S Hybrid Travel Trailer ( previous trailer )
1998 Viking Popup ( previous trailer )
No substitute for experience
 > Slide out stuck?
