RV.Net Open Roads Forum: Fifth-Wheels: Brooklyn Queens Expressway
 > Brooklyn Queens Expressway
Crabbypatty
Long Island, New York
Posted: 04/18/19 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone traveled the BQE in a fifth wheel? Picking up a new to us fifth wheel in a couple of weeks and we will be down by route 78, so the BQE is closer. I am reading conflicting info on Bridge clearances. Our fiver will be 13 feet, or should I just take the GW home and not think about it?
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
ford truck guy
Pennsylvania
Posted: 04/18/19 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
GW to Throgs Neck to 495 ???.. I think I would avoid the BQE..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
kenbert
Long Island,NY
Posted: 04/19/19 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Took the BQE once when I had a Trailer, Never Again.
95 Georgie Boy Encounter 37ft 5.9 cummins DP
01 Saturn SW
Crabbypatty
Posted: 05/11/22 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Thinking about a south bound off of Long Island. Has anyone taken the BQE in a fifth wheel. I am 13’2” tall.
Thx
Sjm9911
New Jersey
Posted: 05/11/22 07:29am Link  |  Quote  |  Print  |  Notify Moderator
The clearances say they are lower then you height. Just a quick search says its passable at higher heights but only in certain lanes. I wouldn't chance it. Accident in the taller lane, now your stuck or worse. But its up to you.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
bucky
Raleigh metro
Posted: 05/12/22 03:58am Link  |  Quote  |  Print  |  Notify Moderator
With a RV you've never actually measured while hooked to your truck I wouldn't take any chances. If you do make sure your insurance is already in place before you hook up.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Rickyrocket
Coventry,RI
Posted: 05/23/22 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Drove tractor trailer on the BQE many times, the bridges are marked12'6 but they are high enough for a 13'6 trailer to pass through without a problem, still wouldn't take an RV on it.
Crabbypatty
Posted: 05/23/22 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Thanks we will druve around and yes I measured my rig when connected. Otherwise there’s no point!
BurbMan
Indianapolis, IN
Posted: 05/23/22 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Took the TT down there a few times when we lived on LI. Not any worse than the GWB, the new Kosciusko bridge is nice, traffic just as bad. The BQE is a designated interstate (I-278) with semi traffic on it, so it must conform to the required 13'6" clearances. I don't recall seeing any clearance warning signs last time we went that way. TT was 12'6". I wouldn't worry about it.
2008 Heartland Big Country 3250TS
SOLD: 2002 Lance 811 Slide-In Camper
2002 Lance 811 Renovation Story!
