RV.Net Open Roads Forum: Fifth-Wheels: Lug Nut Torque
 > Lug Nut Torque
Dave H M
IL
Posted: 04/19/19 06:36am Link  |  Quote  |  Print  |  Notify Moderator
I had a wheel off the fifth wheel camper today. It has been a while.
I am running 8 lug hubs with E range tires.
Went through all the literature and as best as I can figure the torque should be 120 ft lbs. I am kinda skiddish about that being correct. Make take one off today and measure the diameter of the lug bolt and look at some charts.
Should I search further or go with the 120?
Thanks
Super_Dave
Harrisville, UT
Posted: 04/19/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
If you are planning on taking one off, measure torque required to break it free for reference.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
MFL
Midwest
Posted: 04/19/19 06:59am Link  |  Quote  |  Print  |  Notify Moderator
My generic owners manual says to torque lite towables 50-75 lbs, and all others at 85-95 lbs. I have 6-bolt hubs, and set them at 90 lbs. I do think that the bolt size is the determining factor, as well as wheel style (aluminum or steel). On mine, at 90 lbs, rarely do any loosen, unless wheel has recently been removed.
I would not set mine to 120 ft lbs.
Jerry
fj12ryder
Platte City, MO
120 seems a bit high, but not by much. I torque mine to 100-110 lb. ft.
Howard and Peggy
"Don't Panic"
justme
Posted: 04/19/19 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
This is what I use https://www.etrailer.com/question-93673.html
It is a mystery why the RV manufacturer does not provide this information in an easy to find manner.
JTrac
Oklahoma
Posted: 04/19/19 07:22am Link  |  Quote  |  Print  |  Notify Moderator
May not help but I have 8 lug, 17.5 inch, H rated tires on mine. The torque spec is 120.
JimT
2013 Excel Winslow 34RKM, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 04/19/19 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Lighter units generally have 1/2" studs, mid-weight have 9/16" studs, while the heavy weights like DRVs use 5/8" studs. If I remember right 120 Ft Lbs is about correct for 9/16" studs.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
goducks10
There
Posted: 04/19/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
x2
Bipeflier
Centralia, MO
Posted: 04/19/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Lug Torque - E Trailer
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
RobWNY
Jamestown, NY
Posted: 04/19/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
For what it's worth, I have 5 lugs. Written on a sticker attached to the front of my 5th wheel it says to torque to 100 Ft. Pounds
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
 > Lug Nut Torque
