RV.Net Open Roads Forum: Fifth-Wheels: Lug Nut Torque
 > Lug Nut Torque
mapguy
Puget Sound
Posted: 04/19/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
For Dexter and Alko axles the chart on page 75 of the linked PDF file from Dexter axle, will give you the proper answer to the torgue question - it also outlines the proper tightening procedure to use...
Dexter Service Manual -go to page 75
Cummins12V98
on the road
Posted: 04/19/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
"DEPENDS"
My DRV's lugs are 5/8" and have the clamping lug nuts as does my DRW. I torque both to 150.
Page 75 below.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Durb
NW
Posted: 04/19/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
When I was checking on my 8 lug rims with 1/2-20 studs, Dexter warned torque was not to exceed 120 ft-lbs. I keep mine at 105 ft-lbs with aluminum rims. Important, after having your tires changed at a tire shop to go home loosen the lugs one at a time, and re-torque properly.
Cummins12V98
on the road
Posted: 04/19/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
I am thinking the one at a time may not work as you think it would. Personally I have done the same but loosened all nuts then torque.
time2roll
Posted: 04/19/19 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
I just tell the technician the torque I want and expect him to use a hand wrench. Any good shop does this already. I use America's Tire.
675w Solar pictures back up
laknox
Arizona
Posted: 04/19/19 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
120 seems a bit high, but not by much. I torque mine to 100-110 lb. ft.
^^^^^This, with aluminum 80 psi rims. Can't remember what my current rig, with 65 psi Al rims are, though. Gonna have to re-check that.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
laknox
Arizona
Posted: 04/19/19 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Discount Tire uses torque wrenches and when I'd have them put new tires on, I always checked with them on the setting. 105-110 every time. I'd check at home and they all clicked right at 105-110...every time. [emoticon]
Lyle
Durb
NW
Posted: 04/19/19 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Lyle
I just had Discount tire install Endurance tires on my trailer. I watched him use a torque wrench on the lug nuts, he had very poor technique. Proper way to load a torque wrench is to pull on the grip. Most people that push on the grip, or hammer the torque wrench are severely over-applying torque to the fastener. One major tire company reported to me that they tested their people, some were applying torque at 200 ft-lbs over the setting! The torque wrenches Discount uses are box-beam wrenches with very small break angles. Very difficult to stop at the click when pushing on the handle.
How did you check that your lug nuts were accurate? Re- clicking with a torque wrench means they are at least that tight, not an accurate method of testing actual applied torque. There are extremely expensive torque testing wrenches available (made in Japan), but I doubt many have one of those.
If you go with the assumption the lug nuts are overtightened at a tire shop, then loosening them one at a time and re-torquing will work, and not create cross-talk.
azdryheat
Tucson, AZ
Posted: 04/19/19 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Lug nut torque chart
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Cummins12V98
on the road
Posted: 04/19/19 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Lyle
If the torque was more it will still click. I have watched Discount tire torque and they do it correctly. They don’t use a torque stick. They run nuts snug with impact then torque.
 > Lug Nut Torque
