RV.Net Open Roads Forum: Class C Motorhomes: Intermittent failure to start.
 > Intermittent failure to start.
whizbang
Kenmore, WA
Posted: 04/20/19 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Chumlee and BillHoughton nailed it.
Something is sucking power.
Whizbang
2002 Winnebago Minnie
http://www.raincityhome.com/RAWH/index.htm
whizbang
Kenmore, WA
Posted: 04/20/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
By the way.... I try to drive my C once a months during the winter just to keep things working. Well, I got busy with work and accidentally let it sit for 3 months. When I finally turned the key, it started right up.
There is NO WAY you should go flat is just a few days.
bobndot
Posted: 04/20/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Test the 'truck (chassis) battery' using an amp meter to see how much is drawing when its parked . Do not plug the camper into shore power while testing.
Cobra21
minnesota
Posted: 04/21/19 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Is the battery down? If not it could be the brake light switch on the pedal. There is a switch on the brake pedal that needs to be made by depressing the brake to complete the start circuit.
Cruisineasy
Hayward
Posted: 04/25/19 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Mine started doing that. I cleaned the battery terminals and connectors and it solved the problem..
