RV.Net Open Roads Forum: Tow Vehicles: towing with a esclade
Search only in Tow Vehicles
 > towing with a esclade
drsteve
Michigan
Posted: 04/22/19 06:47am Link  |  Quote  |  Print  |  Notify Moderator
An Escalade is the wrong choice for pulling an 8000 lb TT.
1991 Palomino Filly PUP
bartlettj
Forest Grove, OR
Posted: 04/22/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Bionic Man wrote:
I know it is not exactly the same, but I tow a 7000 pound boat with a 2011 Yukon Denali XL.
Some of the issues I have (like trailer sway) shouldn't effect you. It has OK pulling power, but don't expect it to stay in 6th gear. Mine is in 5th most of the time, and will drop lower when it hits a hill.
Going through he mountains of Colorado, I see both engines and transmission temps approaching 250*. Two GM dealers and an independent transmission shop all told me that is par for the course towing heavier through the hills.
When we replace our Yukon in the next couple of years it will likely be with a new style Navigator or Expedition. I believe they have higher towing capacity.
I had the same heat experience with my Tahoe. Now I tow with a Duramax/Allison and the temperature never really moves.
mkirsch
Rochester, NY
Posted: 04/23/19 08:45am Link  |  Quote  |  Print  |  Notify Moderator
What these responses are not articulating is WHY it's not a good idea.
In all likelihood, you will not like the performance and handling of a full load of passengers in an Escalade with that much trailer behind.
By yourself, no problem unless you're a pack rat and the truck is full of junk. With an additional 800lbs of wife, kids, dogs, toys, snacks, bikes, etc., and the 1200lbs of trailer tongue, it's not going to be any fun.
It will be FAR from a death trap. Just irritating to drive, perhaps unpleasant. You won't notice at first due to lack of experience but over time you will.
twodownzero
NM
Posted: 04/23/19 10:28am Link  |  Quote  |  Print  |  Notify Moderator
The real problem is that they seem to be going away from 3/4 ton SUVs (and there never were 1 ton SUVs, and even the 3/4 ton ones never had the suspension and payload ability of a similarly-equipped pickup). There's no reason why an SUV can't be built to be a BETTER tow vehicle than a pickup, but the fact remains that the current offerings aren't. Although I'm now a fifth wheel camper, I might change to a TT based rig if they made an SUV I thought worthy of pulling a big one.
Trailers are bigger and heavier than ever now, taking advantage of the capacity and power new tow rigs have. Unfortunately, SUVs have gone completely the other direction.
There may be legal issues here, too, since nobody has ever tried to make an SUV with a 12,000+ lb. GVWR, it's unclear what legal area it'd occupy.
BenK
SF BayArea
Posted: 04/23/19 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Going away because the majority of SUV/CUV fashion statement crowd does NOT tow heavy
Today's station wagon
There is a 1 ton Suburban, but designed for government business and high dollar rollers who can afford to armor plate them...but...that only has a MTWR (Max Tow Weight Rating) of 3,000 lbs
Before SUV's become the highest margin vehicle for the OEMs...Suburbans (the longest running continuous automotive badge) were real TV's for towing heavy
GMT400's and GMT800's were the last of the 3/4 ton. Yes, the next gen after the GMT800 did have a 3/4 ton, but for the sake of looks...marketing told engineering to 'hide' the receiver behind the bumper
So, the receiver is now part of the bumper and with that, has crumple zone duties....which gets stress raiser notches on the connecting bracket between the bumper/receiver to frame rail
The why of the 1,000 lb max tongue weight rating with a WD hitch system
A 3/4 ton GMT400 (7.4L big block) and GMT800 (8.1L big block) Suburban has the same rear axle assembly as the 1 ton dually of that same year, with the leaf spring pack a bit softer sprung during the initial travel. AAM (American Axle Manufacturing) rates those axles 10,000 GAWR and GM puts on the brakes/springs/etc and re-rates them 6,000 lb GAWR
For the OP, an Esclade 'can do it', but if at the limits/ratings, not well during a MR Murphy meeting.
The 6.2L is aluminum and more hot rod (lower duty cycle rating) than towing (higher duty cycle rating)
[image]Click For Full-Size Image.
-Ben Picture of my rig
bikendan
Camano Island, Wash.
Posted: 04/23/19 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
SUVs became the bigger substitute for soccer moms, for the primary use of transporting families and groceries. So there was less demand for the 3/4 ton ones and EPA restrictions made them less profitable for the manufacturers. I see many SUVs with no factory tow package.
So it's no wonder SUVs are moving away from 3/4 ton models and towing platforms.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
