RV.Net Open Roads Forum: Fifth-Wheels: Plastic Fenders
 > Plastic Fenders
bpounds
Sophmore Brain...
Posted: 07/12/19 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
So now I've ordered a pair of replacements from Icon. Thanks for those who suggested them. Should be here in a day or two. Dang, they've got a slew of them to browse through finding the correct ones. I'll add to this after I've completed the job.
Incidentally, I ordered through Amazon, fulfilled by Icon, and this was quite a savings over ordering direct.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Super_Dave
Harrisville, UT
Posted: 07/12/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder how hard it would be to glass the back of them for added strength.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
bpounds
Sophmore Brain...
Posted: 07/13/19 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
The only place mine cracked was around the screw holes, and the recesses for the screw holes. I think someone creative could reinforce just around those areas. Glassing the whole back sides IMO would just increase the weight and not help.
I found that my driver side was in much worse shape than the other side. I had assumed that was because that side gets all the sun in our parking location. But today I realized that the struts they used to stabilize the lower sheet metal were worthless, and what little there was had vibrated loose. This is along the slide-out. So today I welded in some real struts to stabilize along that side and I'm expecting to see a lot less flexing in my rearview mirror. The passenger side is not a slide-out, and the sheet metal was well supported, so the plastic fender skirt is well support too.
bpounds
Sophmore Brain...
Posted: 07/13/19 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon delivered fast and I got the Icon fender skirts installed today. They are not an exact fit. The radius around the wheel opening is not identical. And the radius around the bottom is not the same either, so it needed to be trimmed. But the overall length and width is very close, similar hole spacing, and with a little trimming to improve tire clearance I made these work. I think the thickness of the plastic is very similar, and I would not consider these an upgrade. Pretty much a straight across trade as far as quality.
Just a heads-up if you need to purchase. This isn't a 15 minute job to swap a few screws. You'll spend some time making them fit. They also don't come with the holes drilled, but it was obvious the originals didn't either and the assembly guy just zip gunned them down fast. It's just as well, since I didn't need to try to reuse the existing holes, and had the freedom to place them where I wanted.
bpounds
Sophmore Brain...
Posted: 07/13/19 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Here is a few pics.
Before...
This was the worst of the tear-outs. Front edge, on driver side.
The clear Gorilla tape worked for a season to keep the skirts from completely tearing loose.
The new skirts had a different radius where it returns under the side.
A little scribing and trimming had those fitting decent.
Not much tire clearance. Maybe these things are intended to be trimmed to fit, I don't know.
A little trimming here made me comfortable with the clearance. Had to do the same thing on both sides of the center drop area.
And after a little touch-up paint, they don't look to shabby. Need to do a little cleaning tomorrow before the tire skirts go back on.
This stuff was a decent color match for blended touchups on the typical RV white.
colliehauler
Mc Pherson KS USA
Posted: 07/13/19 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
I had one bad fender where a tree branch broke it. The Icon fit was very close on my Keystone. They have a lot of fenders to sort through to get the correct dimensions. I predrilled the holes in the fender hopefully to prevent cracks. Not cheap though, with shipping for one fender was $180.
frankwp
Calgary, AB, Canada
Posted: 07/15/19 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue with the screw holes being cracked. I just scuffed the back side around each hole & applied epoxy (slow cure, not the 5 minute kind). A stainless steel washer was also epoxied to each hole on the front side. After curing, I rattle can sprayed it with a new coat of white paint. That was over 2 years ago & that fender still looks like new with no cracks around the screw holes.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
bpounds
Sophmore Brain...
Posted: 07/15/19 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
colliehauler wrote:
...Not cheap though, with shipping for one fender was $180.
The price for one of these on the Icon site was $149, and I didn't get far enough to check shipping, but I'm sure it wasn't included. I paid $120 with free shipping on Amazon. And they drop shipped from some place called Keystone Auto, and were here in 2 days. Not sure if that is related to Keystone RV.
Probably a good idea. The back side is recessed by 1/8" or so, and something to fill that so you could actually clamp them down would help. Some of that epoxy putty probably would work. I upsized the screws to #10 SS and SS washers.
 > Plastic Fenders
