RV.Net Open Roads Forum: Beginning RVing: water heater bypass
 > water heater bypass
njtony
indiana
Posted: 04/21/19 09:27am Link  |  Quote  |  Print  |  Notify Moderator
After my first time winterizing last fall, I questened the placement of the water heater shutoff and bypass valves. My hot and cold valves are placed before the bypass valve. Is this correct?
Old-Biscuit
Verde Valley
Posted: 04/21/19 09:41am Link  |  Quote  |  Print  |  Notify Moderator
When Cold Inlet is closed....water can not flow into WH Tank
When Hot outlet is closed ...water can not flow out or into WH Tank
With Bypass OPEN..water flow from cold water line to hot water line
If water supply is turned on 'bypass mode'...cold water will flow out hotside of faucets---bypassing the WH Tank
3 way system
WILDEBILL308
FORT WORTH , TEXAS
Posted: 04/21/19 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
The illustrations Posted are the way it should be and about the only way it would work. Did you have antifreeze in the hot water tank?
Let us know what you find.
Bill
2003 BOUNDER 38N
5.9 CUMMINS 300 HP
ALLISON 3000MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
BB_TX
McKinney, Texas
Posted: 04/21/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
There are multiple configurations for WH bypass. One uses two 3 way valves instead of three basic shutoff valves. And other variations.
4x4van
California
Posted: 04/24/19 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Very true. Mine has just a single bypass valve (along with a one-way check valve on the "out" line at the WH).
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
njtony
indiana
Posted: 08/06/19 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Had a repair man out and yes water heater was plumbed wrong from manufacture. Reworked plumbing and all is working as should be. Guess the person who installed had an ass backwards moment. And me out $150.00. And now I have a recall on my defective furniture fabric. Coachman is short on quality. And life goes on.
kellem
Shenandoah valley,VA
Posted: 08/07/19 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
On a side note:
Something I always tell other RV's and friends I actually winterize for.
As soon as you winterize your trailer you can instantly de-winterize and return all valves back to operating position as all your really doing is displacing water.
Yes,I'm saying run RV antifreeze through all the lines then simply drain it back out.
Been doing like this for over 20 years.
4x4van
California
Posted: 08/07/19 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
kellem wrote:
On a side note:
Now that's an interesting point. Once all of the water has been displaced by anti-freeze, that anti freeze can then be drained. Still have to rinse the residual anti-freeze come time to start camping again, but...
kellem
Posted: 08/07/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Yes,my apologizes for derailing thread.
It helps the less experienced to return all cutoff/bypass valves back to there home position while memory is fresh.lol
Prevents frying an element in the spring or asking " what happened to my water pressure ".....yes some rinsing required.
