RV.Net Open Roads Forum: Beginning RVing: Low overpasses, etc.
 > Low overpasses, etc.
1320Fastback
Vista, Ca
Posted: 04/22/19 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Only low bridges I've ever encountered has been on rural roads not that basic GPS navigation wouldn't lead you as it did I. Thankfully we are only 10'5" to the top of the AC and have only had to back up once.
If you get off the interstates and away from major cities take every overpass with care especially back east.
1992 D250 Cummins, 5spd, 4"' straight piped, sensors deleted, airbags, DAP injectors, 18cm.
PastorCharlie
NC
Posted: 04/23/19 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
There are 4-5 thousand bridges in the USA with clearances below the federal limits.
DavidandDayle
Guelph, Ont
Posted: 04/26/19 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
I understand that a certain roads commissioner designed the roads to the beaches with bridges that were too low for buses so that certain classes couldn't go.
I have the height of my rig posted on the rear-view mirror in two systems. (My mirror is about 3 times as wide as needed for the rear window.) Once you get off the highway and the truck routes there are all sorts of undersize bridges.
David and Dayle
Rick Jay
Greater Springfield area, MA
Posted: 04/27/19 10:16am Link  |  Quote  |  Print  |  Notify Moderator
suprz wrote:
You're in CT, so stay off any road that ends in the word PARKWAY (like Merrit Parkway) and that goes for any state
While that is generally good advice, you CAN drive on the New Jersey "Garden State Parkway" with your RV, BUT be sure to stay in the center lanes. A few of the arched overpasses have low height warning signs (10 or 11 ft?), but that might even be over the break-down lane. I've driven it many times in our 12' tall class A and never had a problem.
But every other "Parkway" that I know of in the Northeast usually has signage something like "No Trucks or Buses" or "Low Clearance".
Stay on the major highways and you'll be OK. IF you drive in the "boonies", and I can speak from experience in Western Massachusetts, DO NOT proceed down any road that doesn't look like it sees regular truck traffic. There are some roads in Western Mass in my GPS which were logging roads over a 100 years ago, and are unpassable unless you're on horseback or possibly an off-road 4WD Jeep. They start off looking like a normal, small road through a nice neighborhood, and then the pavement disappears, the trees start crowding in on the road and then it gets bad quickly after that. Fortunately, when I had this happen to me, I DID NOT drive the moho down that path because I could tell it was getting scary and I could turn around BEFORE the pavement disappeared. However, I did go back the next day in the minivan to check it out. No lie, I think the road went between this guy's house & his chicken coop, and about 200' after that there was a huge rock in the middle of the road. The road at this point was pretty rutted up and narrow. But the GPS thought we could make it! LOL I was lucky to get out of there in the minivan!
My general rule is NOT to drive in such areas once it gets dark, but not so much for fear of bridges, but for fear of low branches. I'll drive all night on the highways without a problem, but if I have to travel on backroads to get to a campground, I try my best to arrive BEFORE it gets dark. Navigating a new campground in the dark is often no picnic either! LOL
Good Luck,
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (22-Angel, Lexi96.org), 1 girl (17), 2 boys (18 & 15). One Chinook dog (12).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
SteveWoz
Simsbury, CT
Posted: 04/28/19 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Good Luck,
~Rick
Thanks so much, Rick. That's very helpful advice.
Steve
navegator
San Diego CA.
Posted: 04/29/19 09:16am Link  |  Quote  |  Print  |  Notify Moderator
I think that the programers at the GPS companies use Google maps overlaid with the roads indicated, we have found hundreds of streets and roads on Google that simply are wrong or non existing, one example out in the desert Google shows a road in a wash, it actually is a flash flood channel and varies in with from 40 feet to a narrow vertical side channel about 4 feet wide, the floor goes from sand with small rocks and pebbles to areas that are very fine sand and is hard for a person to walk on, if not check the road that goes down Mt. Lemon in Arizona from the fire station at the top of the mountain down to Oracle, today it is closed because to many folks using GPS tried to go down to Oracle and got in trouble and had to be rescued and that was with cars and 4x4s going down and going up the steep hair pin turns discouraged most from continuing.
navegator
tatest
Oklahoma Green Country
Posted: 05/06/19 04:47am Link  |  Quote  |  Print  |  Notify Moderator
Trucker's Atlas generally, but going through urban areas I like to follow truck routes. You live in an area with many low overpasses in urban areas and small towns, roads restricted to passenger car traffic only. Previewing routes in a car is not a bad idea.
Tom Test
Itasca Spirit 29B
