RV.Net Open Roads Forum: Fifth-Wheels: Awning trouble.. Please help!
 > Awning trouble.. Please help!
Duke-44
Wyoming Rockies
Posted: 04/22/19 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I decided to sell my 2012 5iver. It's been in storage since Fall of 2017 and I just took it out this morning so I could show it this afternoon. Everything worked fine except when I went to open the elec. 16' awning. I pushed the switch and all there was, was a click heard near the awning.....
Has anyone had an awning do this??
Please help!
I am wondering if it is stuck.
newman fulltimer
louisiana
Posted: 04/22/19 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
If its a dometic which I'm sure it is the motor is gone from sitting up and water corroding it
agesilaus
North Florida
Posted: 04/22/19 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Breaker or fuse is the first guess/ Could be something keeping it from opening, make sure it's free to operate.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Duke-44
Wyoming Rockies
Posted: 04/22/19 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
It is a Dometic. But it was in totally dry storage with very low humidity in my area.
If it is because of water in the motor it would have to have been very wet when it was put in storage, which I don't remember.
How hard are motors to replace and what do they cost?
Duke-44
Wyoming Rockies
Posted: 04/22/19 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
I thought beaker or fuse, too. But that clicking sound says there is a electrical connection there.
agesilaus
North Florida
Posted: 04/22/19 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
OK I thought you were saying there was ONE click then silence which could indicate an overload that could pop a breaker.
Is it free to move, how about the manual crank? Does that work?
Duke-44
Wyoming Rockies
Posted: 04/22/19 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think there is a manual crank. I am wondering if I should get up there and try to pry it out slightly while my wife presses the switch.
fj12ryder
Platte City, MO
Posted: 04/22/19 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Is there sufficient 12v power in the battery/ies to operate the motor.
Motors are around $150-$200, and not too bad to change. Check by running power directly to the motor connection first.
Howard and Peggy
"Don't Panic"
badboy368
OHIO
Posted: 04/23/19 02:30am Link  |  Quote  |  Print  |  Notify Moderator
Hmmmm was the engine running when you tried to open it? It has safety switch to not be able to open while engine is running.just a thought.
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
MudChucker
Niverville Manitoba
Posted: 04/23/19 04:31am Link  |  Quote  |  Print  |  Notify Moderator
Do you have any lockdown mechanism that you may have forgotten to release? Did you rock the switch in and out, is the click audible with each press of the button? Are you on shore power, if not plug into shore power and try again. Try. 12 volts directly to the awning.
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
