RV.Net Open Roads Forum: Ford V10 with 4 speed or 5 speed transmission
 > Ford V10 with 4 speed or 5 speed transmission
skes
Michigan
Posted: 04/23/19 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Looking at my first class A. I've settled in on a used 29 or 30 foot Winnebago. It looks like they changed from a 4 speed to a 5 speed in 2006. I'm wondering what difference I would expect to experience between the two transmissions. Thanks in advance.
Veterans’ Park, Monterey, California
Posted: 04/23/19 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Night and day from my two previous Tahoe four speeds to the 2015 six.
DrewE
Vermont
Posted: 04/23/19 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
The top two gear ratios are the same between the two transmissions, I believe, so there's not a whole lot of difference on the highway where it generally is in one of those two gears (and the gap between them is plenty large). That being said, the controller for the five speed is rather more sophisticated and it has tow/haul mode rather than a simple overdrive off, and tow/haul is a definite plus for a motorhome.
Both are pretty reliable transmissions if given appropriate care and feeding. The five speed might be a little bit sturdier overall, possibly.
pianotuna
Regina, SK, Canada
Posted: 04/23/19 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Hardly any difference, and no mileage advantage.
Regards, Don
dodge guy
Bartlett IL
Posted: 04/23/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Where you will notice the difference is in the gear spacing from a standing start. He 4 speed has a very wide spread. Meaning the rpm drop from first to second is ridiculous! It was very noticeable in my 02 V-10 Excursion. However a swap from 3.73 to 4.30 gears took care of that and made OD useable on the highway. The 5 speed got rid of that rpm drop. I have the 5 speed in our new to is 2012 V-10 class A. It is a much better setup for the V-10.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Gjac
Milford, CT
Posted: 04/24/19 06:09am Link  |  Quote  |  Print  |  Notify Moderator
The greater advantage to buying a MH 2006 or newer chassis is the increase of HP and 3 valve engine (362 HP).
steved28
Bellingham,MA,USA
Posted: 04/24/19 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure of this? I don't think my 08' had a 3 valve engine in my class C. I have it now in my 2019 class A. Noticeable difference, especially mated to a 6 spd. tranny.
2019 Winnebago Sunstar LX 35F
2000 Jeep Wrangler TJ Sahara
D.E.Bishop
Eagle Rock, CA
Posted: 04/24/19 07:18am Link  |  Quote  |  Print  |  Notify Moderator
I have never had a stock V10, mine has the Banks Power Pack with Trans Control. I have read here that without some tweeking the old four speed trans on cruise control there was a lot of gear searching on very slight grades. I run on CC a lot and don't have that problem. I am very happy with my 2001 engine.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
jy
south east mich.
Posted: 04/24/19 07:19am Link  |  Quote  |  Print  |  Notify Moderator
I had a 99 coachman 33 foot with Im assuming the 4 speed.Transmission was so so.Bought and installed the Banks transcommand.Best money I ever spent.
99 Coachmen 322QB, Ford V10,18 foot Load King open trailer, 2007 Mustang GT Toad, Gibson exhaust,Royal Purple lubricants.Recently retired and planning on doing more RV'ing.
carringb
Corvallis, OR
Posted: 04/24/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
He's correct. I thought the changeover was 2005 but it might have been 2005. Your '08 definitely had the 3-valve. The 2016+ does make more low-end torque however, even though it's rated at less HP for greenhouse-gas emissions compliance.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
