RV.Net Open Roads Forum: Class C Motorhomes: Battery recommendations
 > Battery recommendations
suprz
rhode island
Posted: 04/25/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I used to always get Sears Diehard Gold batteries. Never ever had a problem with any of them. But my local store is now closed
Proud father of a US Marine
Gjac
Milford, CT
Posted: 04/25/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
If you travel a lot especially out west I would get the Walmart starting battery because there are Walmart's every where you travel. My last starting battery in the MH from Walmart lasted 9 years. I changed the tow cars batteries twice on trips one under warranty. The newer batteries have a 5 year warranty.
Dusty R
Charlotte Michigan 48813
Posted: 04/25/19 09:59am Link  |  Quote  |  Print  |  Notify Moderator
I lean towards Deka batteries.
pnichols
The Other California
Posted: 04/25/19 10:16am Link  |  Quote  |  Print  |  Notify Moderator
suprz wrote:
I'm just looking for a new chassis battery for my 2006 E450 super duty
Figured it's time for a new one seeing how I have no idea how old this one is, and I think it's getting weak
I'd recommend the same approach for the engine battery as for the coach batteries: Install the largest and best battery that will fit and that you can afford. The last engine battery I had installed in our E450 based Class C was one of the Ford OEM batteries specified for their diesel pickups, which just happened to fit.
The way I figure it, you aren't going to find a Walmart in places like this: [emoticon]
Phil, 2005 E450 Itasca Spirit 24V
suprz
rhode island
Posted: 04/25/19 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
I just checked with my local ford truck center and a new oem with 900CCA is 139.00. Before the core refund. That's not too bad. I've heard good things about the ford I'm batteries
pnichols
Posted: 04/25/19 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
You shouldn't be disappointed with that battery.
However, even for a starting battery ... I actually prefer AGM technology for that battery ... like the ultra-reliable AGM starting battery I have in my 4X4 PU.
I find it tough to remember to check the water level in my E450 motorhome's heavy duty liquid acid OEM Ford starting battery - good as the battery might be otherwise. [emoticon]
RambleOnNW
Pacific Northwest
Posted: 04/25/19 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
I like the BatteriesPlus X2Power AGM batteries so when the Group 65 flooded battery was failing I replaced it with this: https://www.batteriesplus.com/battery/ca........per-duty/2006/v10-6.8l-650cca/sli65agmdp
5 year full replacement. When dry camping I like another AGM deep cycle source.
It was 10% off ordering online and picking up in store.
The Duracell AGM looks good too:
https://www.batteriesplus.com/battery/ca........super-duty/2006/v10-6.8l-650cca/sli65agm
* This post was edited 04/25/19 08:47pm by RambleOnNW *
2006 Jayco 28', E450 6.8L V10, Bilstein HDs,
Roadmaster Anti-Sway Bars, Blue Ox TigerTrak
Gjac
Milford, CT
Posted: 04/27/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I don't know much about the AGM batteries and know there are advantages such as not having to add water and vibration but how long do the last compared to wet cells? At $200-$300 apiece I would hope they would last at least twice as long.
pianotuna
Regina, SK, Canada
Posted: 04/27/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Gjac,
If the owner of flooded batteries is careful, their life span may often exceed those of AGM. If the owner is careless then AGM may win the life span challenge hands down.
Where AGM shine is their almost zero need for maintenance, and superior discharge and charging rates.
I certainly don't miss laying down in the snow to check electrolyte levels.
Regards, Don
Gjac
Milford, CT
Posted: 04/27/19 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Don, so it is maintenance that justifies the cost? I wish my batteries were on a slide out to make them easier to add water and clean the terminals. It is just hard for me to justify spending 3 times the cost per battery if they don’t last at least twice as long.
