RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): Pex tubing.
opnspaces
San Diego Ca
Posted: 04/25/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
If you have access to the run of PEX from the T to the washer hookup then cut it somewhere in the middle of the run and cap it. Then take the capped stub and find a way to fix the capped end higher than the T fitting. Water will drain out of the tube when it loses pressure while you're winterizing it.
Before you sell the coach just remove the cap and use a coupler to put the cut pieces of hose back together.
If you only have access to the T then remove it and replace with a straight coupler.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Cocky_Camper
Rock Hill, SC
Posted: 04/25/19 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
The only was that would work is the cut the T where the line goes to the washer and replace it with a straight coupling.
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
grizz272
frozen tundra, WI
Posted: 04/25/19 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
I think I will try and find the T and remove it and put a straight coupler in its place. When we sale it I will connect it again.
grizz272
frozen tundra, WI
Posted: 05/30/19 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
The camper was at the dealer getting some work done and I mentioned I wanted to make winterizing the washer hook up easier. The dealer said no problem we can do that. The dealer dded two shot off valves in the basement for the washer hook up at no charge. I was shocked.
Corkey05
Washington State
Posted: 05/30/19 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
No charge is unheard of, you must have a great smile.
But seriously, if you shut off the valves how do you drain the lines?
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
BarneyS
S.E. Lower Michigan
Posted: 05/31/19 06:52am Link  |  Quote  |  Print  |  Notify Moderator
???? Open the valves?[emoticon][emoticon]
Barney
Not towing now.
