RV.Net Open Roads Forum: Fifth-Wheels: Water tank size.... What would you do?
 > Water tank size.... What would you do?
Page of 5
time2roll
Posted: 04/26/19 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
laknox wrote:
time2roll wrote:
I would verify the pickup tube extends to the bottom. I would also slightly tilt the trailer toward the pickup tube to get all you can. I can go a week with three of us on 50 gallons if we mostly skip the shower. Otherwise I would figure out how to carry more water.
There shouldn't be a "pickup tube" as a =proper= fresh water tank should have a bottom low-point pickup molded into it, just as your waste tanks should have a low-point drain molded into the bottom.
Lyle
OK this is how mine is set up with a dip tube.
Also I can get a short fill if the trailer is tipped toward the fill side leaving probably a 10 gallon bubble in the tank. Combined with tipped away from the pick-up tube when parked I can lose 15/20 gallons easy.
675w Solar pictures back up
Rwake901
Central, Illinois
Posted: 04/26/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
bpounds wrote:
B.O. Plenty wrote:
Another 20 gals. would only extend your camping by one day...
You obviously don't boondock much.
That is the point. If 40 gallons gets the OP two days then the 60 gallon spec only goes three days.
Need more conservation.
So you think 10 gallons per person per day is too much? This includes a shower, brushing your teeth, using the toilet, and washing dishes. I bought this to use not use the campground facilities. If I wanted to use theirs I would have bought a tent. lol
bpounds
Sophmore Brain...
Posted: 04/26/19 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't matter what we think. It's your camp. We use around half that. Some folks use even less.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
jdb7566
minnesota
Posted: 04/27/19 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Allworth wrote:
Somebody is using WAY too much water.
My thoughts exactly
B.O. Plenty
Minnesota
Posted: 04/27/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Thank you. Good to see others have the same idea.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Rwake901
Central, Illinois
Posted: 04/29/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
B.O.
So how did this go from the manufacturer misrepresentation of the size of their fresh water tank to I use too much water?? The amount of water we use is irrelevant here. This is about being lied to by the manufacturer not how much water we use.
goducks10
There
Posted: 04/29/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
X2.
* This post was edited 04/29/19 08:34am by an administrator/moderator *
laknox
Arizona
Posted: 04/29/19 09:52am Link  |  Quote  |  Print  |  Notify Moderator
ABSOLUTELY!!! [emoticon]
Lyle
* This post was edited 04/29/19 01:43pm by an administrator/moderator *
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
time2roll
Posted: 04/29/19 10:22am Link  |  Quote  |  Print  |  Notify Moderator
How long do you expect to go with the on board water system?
If you use 20 gallons per day and expect to go a week I would be looking for an RV with 140-200 gallon supply and waste tanks to match.
We have made 10 days on our rated 50 gallon tank (unverified). This is three of us using the camp facilities to shower and restroom during the day.
I don't think you are going to get very far with the manufacturer with the change of specifications. We can possibly give ideas on conservation or adding additional capacity but it will be up to you to press the issue with the dealer or RV manufacturer.
tragusa3
upstate south carolina
Posted: 04/29/19 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
I can be forgiving of honest mistakes. However, 20% off on such an important variable is unacceptable to me. Not that it would matter if you didn't, but did you specifically discuss water capacity with the dealership?
At the very least, I would accept the dealer paying for a water bladder and any necessary pump system mods.
New to us 2011 Tiffin Allegro Open Road 34TGA
Join us on the road at Rolling Ragu on YouTube!
Page of 5
