RV.Net Open Roads Forum: Tech Issues: how often should the chassis be lubed?
 > how often should the chassis be lubed?
anon125
anywhere
Posted: 04/25/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
ours was lubed (we hope) in 2014. did a 3500 mile trip to socal and back, had the engine serviced then parked it in a barn till now.
thanks all
2006 Itasca sunova 29r
wildtoad
Blythewood, SC
Posted: 04/25/19 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
You should get it done now if it’s been stored for 5 years. I would think under normal use once a year should be fine.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
IB853347201
Eastern Ontario
Posted: 04/25/19 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Ours is a 2010 Itasca Suncruiser. According to the manual the chassis lube is due at every oil change. Also the PowerGear levelers require lubing at the same interval.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 04/25/19 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
Chassis lubing is soooooo.......YESTERDAY
Obsolete like doing a convergence on a color tv set
Almagard 3752 is to grease what DeOXIT D100L is to electronics cleaners.
Or Woolrich clothing is to Wal-Mart rags...
I pack bearings, After 10 years 100k miles they look like they were done yesterday. Same for ball joints, tie rod ends, driveshafts, etc.
wildtoad
Blythewood, SC
Posted: 04/26/19 05:38am Link  |  Quote  |  Print  |  Notify Moderator
Yes chassis lubing is yesterday technology for most vehicles. Unfortunately not so for Ford F53 based RVs. There are 10 fittings (I think).
BarabooBob
Baraboo, WI
Posted: 04/26/19 07:14am Link  |  Quote  |  Print  |  Notify Moderator
If the chassis has grease fittings, they should be lubed at every oil change. Use a high quality grease and put in just enough to get the rubber boots to plump up just a little bit. Do NOT put in so much grease that you can see it come out around the boots. The boots are suppose to be a pressure system that pushes the grease back into the joint.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
SidecarFlip
SE Michigan
Posted: 04/26/19 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Might be yesterday but yesterday lasts a long time. Today with plastic inserts and a dab of grease equals premature failure. Roads are worse, suspensions take a pounding, alemite fittings and quality teflon based synthetic grease is the recipe for longevity.
I have 23 fittings on my F350 pickup underneath. All get greased every oil change.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
anon125
anywhere
Posted: 04/27/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone.
Now we need a chart to show the independent mechanic where they are for a 2006 ford chassis!
Brian in Michigan
S.E. Mi.
Posted: 04/29/19 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
I still have my color bar generator and my Sencor VA48 analyzer along with my Heathkit VTVM[emoticon]
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
Dutch_12078
Winters south, summers north
Posted: 04/29/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
anon125 wrote:
Thanks everyone.
These might help...
Dutch
2001 GBM Landau 34' Class A
