RV.Net Open Roads Forum: Fifth-Wheels: New Duramax owner hitch question
 > New Duramax owner hitch question
mxdad777
Ca
Posted: 04/26/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
I picked up a new 2019 GMC Duramax today and it has the optional 5th wheel/goose neck option installed from the factory. My question is, what hitch do you all recommend for the puck system? In my research I can only find 2 different models. One by B&W and one by Curt. Are there any others I should be looking at? You GM owners, which one do you prefer?
Thanks!
2018 Rockwood Signature 8299BS 5th wheel
2019 GMC Duramax 4x4
Bigfoot affair
Sweet Grass
Posted: 04/26/19 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
Short bed? If so Pullrite makes a auto slider that fits the pucks now.
mxdad777
Ca
Posted: 04/26/19 11:28pm Link  |  Quote  |  Print  |  Notify Moderator
It is a short bed, but the 5er I bought has the Reece Revolution pin box so I don’t need a slider. Thanks though for the reply.
WTP-GC
FL
Posted: 04/27/19 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
When you say "5th wheel/gooseneck option", are you referring to the 4 pucks or the ball in the middle of the bed? B & W makes a great product for both options. If it's the ball in the bed, you may want to consider the Andersen Ultimate Hitch as well if you're looking for light-weight and simplicity. I've used both and enjoyed them equally.
Duramax + Grand Design 5er + B & W Companion
SBGTF
pcm1959
home
Posted: 04/27/19 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Hensley offers a puck adapter for the Trailer Saver BD3 (excellent hitch) and the heavier B5 will fit directly into the GM puck system without an adapter.
Do yourself and your fiver a favor and get an air suspension hitch.
* This post was edited 04/27/19 06:43am by pcm1959 *
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
rickeoni
home
Posted: 04/27/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
I use the Reese picture frame adaptor with my BD3, $200 cheeper. X2 on the air hitch.
2008 F450
2007 Adventurer 85WS
2012 Haulmark "The Garage"
2016 Outdoors RV Glacier Peak 26 RKS
hbillsmith
www.RVroadtripper.com
Posted: 04/27/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
I use the Andersen Ultimate in my 6.6' bed Duramax. With a Double Cab, the bed is a so called "Standard Bed 6.6ft". With a Crew Cab its a "Short Bed 5.5ft". My Pinbox is the MorRyde Rubber Pin Box and I must say the ride is great and I always recommend that combo.
When I last spoke to Andersen about the MorRyde compatibility they advised it is their best combo but the Andersen Ultimate works fine for just about any hitch EXCEPT the Reese Revolution. For the Reese Revolution you must tow with the Revo in locked position such that the pivot point is over the ball and not at the Revo's pinbox spinner. When parking or in narrow turn situations it is ok to unlock the Revo but you just shouldn't do your regular towing with the Revo unlocked.
Wildcat2016-295rsx GMC2015-2500HD-DblCab D'max/Allisn+4x4 6.6'Bed
Maxxis235/80/16E;Andersen Ultimate2+4"offset;Airlft1 WirelessComp;GroundCtrl3;MorRyde RubbPinBox+CRE3000;3-Slidecovrs;Champion3100w/DIY ExtndRun;10'Portabote+5hp;Furrion48cam
Visited States
kennethwooster
Perryton Tx USA
Posted: 04/27/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I would only consider the B&W. I’ve used a lot of different hitches over the years. Got a Ford F-350 with pucks. Installed B&W and was shocked at how well it worked.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
mxdad777
Ca
Posted: 04/27/19 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
WTP-GC wrote:
Thanks!
It has both the 4 puck slots as well as the center goose neck installed from the factory.
Durb
NW
Posted: 04/28/19 08:33am Link  |  Quote  |  Print  |  Notify Moderator
If you are going to use a B&W Companion hitch, get the one that mounts in the pucks, not the bed mount that utilizes the gooseneck ball. B&W states that hitch is not to be used with your type of pin box. Andersen is out for your pin box.
My vote is for Trailer Saver BD5. High quality, comfortable tow, gear protection. Fits right in your pucks. Only downsides are weight and wallet assault.
