RV.Net Open Roads Forum: Fifth-Wheels: New Duramax owner hitch question
 > New Duramax owner hitch question
pcm1959
home
Posted: 04/28/19 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
BD5 air hitch. Robust quality and very good for your trailer. I would not have anything but an air hitch of some brand.....definitely not a rigid hitch.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
AUwing2
SE Wisconsin
Posted: 04/28/19 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Have the Curt Q20 with the factory puck system - no problems.
jaycocamprs
Ringgold Georgia
Posted: 04/28/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
kennethwooster wrote:
I would only consider the B&W. I’ve used a lot of different hitches over the years. Got a Ford F-350 with pucks. Installed B&W and was shocked at how well it worked.
X2 B&W all the way
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Sport45
Not far enough from Houston, TX
Posted: 04/28/19 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Shocked that it worked well? For the extra money they cost and all the hype around them I think I’d be shocked if it didn’t work well.
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
mtofell1
Oregon
Posted: 04/28/19 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for B/W. I'm sure others are nice as well but I just have experience with B/W and a cheapo Reese years ago. Whatever you do, don't be afraid to spend money. There is nothing worse than a cheap hitch.
Aside from the great functionality of the B/W, their customer support is awesome. I called once with a question and within a couple minutes was transferred to one of the engineers who designed my hitch. They guy was amazing and totally helped me out.
Cummins12V98
on the road
Posted: 04/28/19 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Curt is known to promote chucking. Simply look at the heads pivot point being several inches below the kingpin connection.
B&W’s is even with the kingpin connection height.
Oh yea if it matters Curt is Made in China. B& W is US Made.
Curt is known to be hard to disconnect when truck and RV are on different angles.
B&W is always easy to hitch and in hitch. Also simple solid no question if you are hitched.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 04/28/19 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
For all you Andersen guys, OP said he has a Reece Revolution pin box. That will not work with a Andersen hitch.
B&W RVK3700 20K or RVK3705 25K hitch.
For your 2018 Rockwood 8299BS the 20K is plenty of hitch.
BTW as Ron says Curt 5th wheel hitches are built in china!
mxdad777
Ca
Posted: 04/28/19 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
I picked up a great deal on a B&W Companion puck system. I have everything hooked up and even with the arms on the lowest setting, the trailer isn’t exactly level. It’s a little high in the front and my truck is squatting a little. Is this acceptable, or do I need to make some adjustments?
PS so far I love the hitch. Looks very well built and easy to use..
* This post was edited 04/28/19 11:45pm by mxdad777 *
2018 Rockwood Signature 8299BS 5th wheel
2019 GMC Duramax 4x4
MFL
Midwest
Posted: 04/29/19 05:19am Link  |  Quote  |  Print  |  Notify Moderator
That is a nice looking rig! It is best to be level, if you have enough bed rail clearance (6 inches minimum). You may be able to raise the pin box one setting. IMO, you are close enough, and many are towing much more nose-high than that. Mine is about an inch nose-high and tows great.
Congrats on finding a good deal on a great hitch. Welcome to the B&W Fanboy Club
Jerry
lee worsdell
elmvale
Posted: 04/29/19 05:28am Link  |  Quote  |  Print  |  Notify Moderator
I would go with b&w hitch. I no how a lot of people on here on built in USA so go with it. Curt is shipped from china and put together here from what I was told. Bolts aren't as high a grade also.
