RV.Net Open Roads Forum: Around the Campfire: Needing small engine yard tool experts
 > Needing small engine yard tool experts
MFL
Midwest
Posted: 04/27/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
I am tired of dealing with mixing gas/oil for two different tools. My Stihl leaf blower uses Stihl 50:1 synthetic oil, and my Weedeater uses 40:1 Weedeater dino oil mixture. I am thinking, just go with the 50:1 Stihl synthetic for both units. I am thinking the 50:1 synthetic, will be sufficient lubrication for the Weedeater. Am I wrong?? What would you do.
Jerry
Dutch_12078
Winters south, summers north
Posted: 04/27/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
I kind of split the difference and have used an easy to measure 3 ounces of oil per gallon of gas ratio for both 50:1 and 40:1 tools for years with no problems.
Dutch
2001 GBM Landau 34' Class A
Lessmore
Canada
Posted: 04/27/19 11:52am Link  |  Quote  |  Print  |  Notify Moderator
I use Stihl 2 stroke oil with my 1988 Lawn Boy 2 stroker lawn mower. I use the ratio recommended by Lawn Boy. Yeah I know modern technology, new improved and synthetic 2 stroke oil, etc. But I still use the 1988 ratio determined by Lawn Boy and Stihl 2 stroke synthetic as I can't get Lawn Boy oil anymore. It works well and I only notice a blue cloud on immediate start up, which quickly goes away after the choke is reset.
Decades ago a small engine repair guy told me that a Lawn Boy engine will go forever as long as you make sure you mix the oil and gas at the factory ratio.
After 31 years of hard use..so far...so good.
georgelesley
Tennessee
Posted: 04/27/19 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t recall the exact name, Optica or something like that. It is a two cycle oil that claims to run any two cycle engine on the mix recommended on the bottle, one ratio for all 2 cycle engines. When we lived in Northern MN I used it at the same mix for everything from. A 16:1 chain saw to 50: 1 old outboard motors. In several years doing that, never had a problem.
I no longer have any 2 cycle items so no longer use it.
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
georgelesley
Tennessee
Posted: 04/27/19 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
I just remembers I have one bottle left of the stuff I mentioned. It is called Opti-2. The mix is 1.3 oz per gallon. Always worked for me. And it claims to stabilized the fuel for long tern storage as well. My stuff always started right up using it, even my chain saw that did not always get run every year. No, I have no financial interest in the company, just a happy user.
GeoBoy
Northeast
Posted: 04/27/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
You will be fine using the Stihl synthetic oil in the Weedeater at 50:1. Don’t use the weedeater oil at all.
MFL
Midwest
Posted: 04/27/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
My problem is I bought a good supply (2 6-packs) of Stihl HP synthetic due to getting good price, with purchase of leaf blower. That Opti-2 is rated well on Amazon, with many good reviews. But with only a small amount of fuel used, with my weedeater (less than 1/2 gal) I'm hoping to just use the Stihl HP, already mixed, ready to go, if no one posts why I should not. [emoticon]
Thanks for your reply!
Jerry
* This post was edited 04/27/19 03:56pm by MFL *
MFL
Midwest
Posted: 04/27/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
This is what I wanted to hear! I am out of weedeater oil, hate to go buy more, mix in another can, trying to split the small bottle of oil, to mix with 1/2 gal of gas.
Hearing what I wanted to hear, reminds me of the guy, with the too small truck, waiting for just one person saying it will work, when 20 other posters said it would not.[emoticon][emoticon]
Thanks,
Jerry
Sport45
Not far enough from Houston, TX
Posted: 04/27/19 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
I use Stihl synthetic at 50:1 in all my 2-stroke engines. Even the old chainsaws that were spec’d at 16:1. Just had to adjust the mixtures so they would run right. When you replace oil with gas (or vice-versa) by changing the ratio you need to make sure the engine isn’t left running lean which can quickly burn a hole in a piston. Too rich will foul plugs in a hurry.
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
MFL
Midwest
Posted: 04/27/19 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
My understanding, by removing a little oil, 50:1 which means more gasoline, less oil in the mix, may cause the Weedeater to run slightly rich, when 40:1 is the spec. With the Stihl oil being high quality synthetic, I'm expecting good lubrication.
Jerry
