RV.Net Open Roads Forum: Class A Motorhomes: Turbo leak
 > Turbo leak
Page of 7
mike brez
Unknown
Posted: 04/28/19 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Just discovered a leak were the turbo bolts to engine. Peice of gasket missing. I'm blowing black smoke under load and have a loss of power. Also looks like a nut is missing from stud on right side. I have another 3-4 hour last leg of our trip tomorrow.
So opinions on runnng like this for 4 hours. I much rather fix this in my backyard at home and know were to get parts.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Twomed
FL winters and then somewhere cool
Posted: 04/28/19 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Run it....start soaking those bolts/nuts. I've seen worse.
Happy Trails ">
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
midnightsadie
ohio
Posted: 04/28/19 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
soak them now and every time you stop . any help is better than snapping one off.use a pentrating oil not wd 40.
C20
Shawnee KS
Posted: 04/28/19 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Won't hurt the motor at all. It will smoke and be down on power but good to run
08 Itasca 40 FD
97 jeep wrangler
16 HD CVO Street glide
2015 Challenger Hellcat
2016 Ram Eco Diesel
wolfe10
Posted: 04/28/19 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, run it home-- probably avoid full throttle as much as you can.
Then, soak, soak, soak before even trying to break those nuts loose. Soak the top of the studs as well, you do not care whether the nut or stud come loose-- either works!
And, if they don't come loose, consider a torch and/or sharp raps to break them loose rather than breaking them off.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Airdaile
On The Road
Posted: 04/29/19 06:14am Link  |  Quote  |  Print  |  Notify Moderator
Isn't enough WD-40 for that. Get the torch out.
sailor_lou
Connecticut
Posted: 04/29/19 07:04am Link  |  Quote  |  Print  |  Notify Moderator
As the others have noted, this is not a job for WD40. Use a true penetrating oil like Kroil (the best IMO) or PB Blaster. Good luck and safe travels.
Lou
05 Travel Supreme Envoy
* This post was edited 04/30/19 06:34am by sailor_lou *
wolfe10
Posted: 04/29/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
sailor_lou wrote:
As the other have noted, this is not a job for WD40. Use a true penetrating oil like Kroil (the best IMO) or PB Blaster. Good luck and safe travels.
Lou
AGREED!
SidecarFlip
SE Michigan
Posted: 04/29/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Best penetrating oil I've ever found (and cheapest too) is a mixture of acetone and Dexron / Mercon ATF. Mix 1/3 ATF with 2/3 rds Acetone and put in a sprttzer bottle. Eats rust and loosens stuck bolts. I keep a spritz bottle handy all the time.
Unless yo are crack home wrench, I'd take it to a shop to have it done. The turbo / manifold assembly has to come off, new gasket put on and everything buttoned up again, not for the home shop really unless you have the tools and a means to remove the parts safely.
You ca run it that way, no issue but like was stated above, soak the studs and nuts down (all of them, nit just that one more tan once before you get home. That will allow the removal without snapping a stud off which is a royal PITA and time consuming to extract. Most times they break off flush and have to be drilled out with a die reclaim bit... (solid tungsten carbide). Don't think you have one of those. Soaking them with penetrating oil will facilitate removal and save you a bundle in the end.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Ivylog
Blairsville, GA and WPB, FL.
Posted: 04/29/19 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
I would run it, soak it, even heat the nuts when you get home. I would run a file over both surfaces and if the studs come out instead of the nuts, replace with SS all thread.l and SS nuts.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
Page of 7
 > Turbo leak
