RV.Net Open Roads Forum: Travel Trailers: Trailer safety chain hooks and F150
 > Trailer safety chain hooks and F150
RonRN18
Roseville, CA
Posted: 04/28/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
I am having issues with connecting and disconnecting the safety chain hooks to the hitch mount of my 2016 F150 truck. It is very difficult to get just the proper angle to get them hooked. The gauge of the steel of the hitch mount holes, the size of the holes and the thickness of the hooks makes this very difficult. Has anyone else had a similar issue? Is there some type of fix that is safe to make connecting and disconnecting the safety chains easier?
2016 Ford F150 XLT SuperCrew FX4 with 5.0L V8
2019 Mesa Ridge 2410RL travel trailer
philh
Belleville MI
Posted: 04/28/19 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Get the angle right and they will slip right on. My wife was fighting with them, until I showed her how to align the hook to the slot... she's a pro now
MitchF150
Puyallup, WA
Posted: 04/28/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue and just got larger size hooks for the safety chains. Got them from one of the box DIY stores..
Sure, they are made in China.... But, they clip on and clip off a lot easier than the ones that came with the trailer so works for me.
Good luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2003 Prowler Lynx 722F #5000 GVWR and weighs every bit of it! "> Happy Camping!
treyster
Ohio
Posted: 04/28/19 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I'll chime in here, I have the same issue with my 2016 F150. I ended up getting caribiners to add to the end of my chain link and use them to attach to the truck. I think they are 7/16" diameter so it's tensile strength is plenty high. They still require a little rotation and twisting but it's better than the safety chain hooks. Also they added just enough length. I think I bought them at Lowe's but maybe got them from Amazon.
KD4UPL
Swoope, VA
Posted: 04/28/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
The chain and hook department of your local hardware store can solve your problem.
BB_TX
McKinney, Texas
Posted: 04/28/19 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried putting the hooks thru from the bottom of the plate? My hooks, with wire retainers, on my utility trailer are difficult to hook to my F350 from the top. But easily go in from the bottom.
Bobbo
Wherever I park
Posted: 04/28/19 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
Took me a couple of times to learn the proper angle. Now, they go on just fine. Lie down and watch them from underneath while hooking them up and you will learn the proper angle. Once you have that mastered, you won't need to like down anymore to get them hooked.
Bobbo, Linda and the furry kid (45 pound rescue)
dodge guy
Bartlett IL
Posted: 04/28/19 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
I changed the hooks on mine. They should be easy to change out. Just make sure the ones you get are rated for more than you need!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
cavie
Posted: 04/28/19 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
buy 2 Threaded carabiners/link extensions from you local Hardware store
ROBERTSUNRUS
Salem, Oregon
Posted: 04/28/19 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]Hi, as already mentioned, hook from the bottom.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
