RV.Net Open Roads Forum: Travel Trailers: Trailer safety chain hooks and F150
 > Trailer safety chain hooks and F150
D.E.Bishop
Eagle Rock, CA
Posted: 04/28/19 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
buy 2 Threaded carabiners/link extensions from you local Hardware store
X2. I installed the threaded chain links and applied some red loctite to the threads. Seems that folks like them and some are too cheap to pay $5 or so in the store. Now it's real easy to hook and unhook the safety catch hooks on my safety cables.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
D.E.Bishop
Eagle Rock, CA
Posted: 04/28/19 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, it took so long for my first post, I gave up and reposted.
Jebby14
Windsor Ontario
Posted: 04/29/19 03:47am Link  |  Quote  |  Print  |  Notify Moderator
I have large threaded caribeaners on my chains. no problems now.
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
Boomerweps
Hills of PA
Posted: 04/29/19 05:58am Link  |  Quote  |  Print  |  Notify Moderator
I use shackles on my Ford Explorer factory hitch. The factory chain loops are too thick for my TT safety chain hooks. Change angle, top or bottom, doesn’t matter. I had to hammer them on leaving the dealer and hammer them off at home. If you look at the hitches on pickups while at stop lights, you’ll see many with shackles or chain loops left attached.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
rrupert
NW PA
Posted: 04/29/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I had this problem on my 2012 F150 until I learned to put them on correctly. Point the hook end up and pull it through the loop from front to back, or towards you. Works slick as a whistle. Taking off is just as easy.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
BarabooBob
Baraboo, WI
Posted: 04/29/19 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
(I also had a problem with my F150. As someone suggested, I laid on the ground and looked at the best way to hook up to the hitch. After doing that and showing my wife how they fit, we both can hook them up without looking.
Bob & Dawn Married 30 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
AmericalVette
Missouri
Posted: 04/29/19 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I got these for my F350 due to the same issue. These are also available at some of the "big-box" hardware stores, Tractor Supply, etc. https://www.bulletproofhitches.com/products/5-8-channel-shackle-for-safety-chains?utm_medium=cpc&utm_source=google&utm_campaign=Google%20Shopping&gclid=EAIaIQobChMI-IOOxpL24QIVR77ACh2s2AMmEAQYAiABEgKEJ_D_BwE
Times fun when you're having flies!
Huntindog
Phoenix AZ
Posted: 04/30/19 03:13am Link  |  Quote  |  Print  |  Notify Moderator
What are the carbiners you guys are using rated for?
I have never seen any that come even close to what I would need.
Larger hooks did it for me on my dually.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
dodge guy
Bartlett IL
Posted: 04/30/19 07:24am Link  |  Quote  |  Print  |  Notify Moderator
I agree. I wouldn’t trust any caribiners no matter their rating. Larger hooks are the simplest and safest way to go!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
D.E.Bishop
Eagle Rock, CA
Posted: 04/30/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I think what they are really talking about are threaded links. I googled threaded links and got quick links and caribiner. All correct I guess.
