RV.Net Open Roads Forum: Travel Trailers: Trailer safety chain hooks and F150
 > Trailer safety chain hooks and F150
CavemanCharlie
Storden,MN
Posted: 04/30/19 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
rrupert wrote:
I had this problem on my 2012 F150 until I learned to put them on correctly. Point the hook end up and pull it through the loop from front to back, or towards you. Works slick as a whistle. Taking off is just as easy.
Ya, this is what I do on my 2011 F150 as well
Boomerweps
Hills of PA
Posted: 05/01/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Looking forward to not using the shackles on my new F150. The F150 uses plate steel for the safety chain loops. My Explorer used tightly curved, very thick, round stock for the chain loops.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
OleManOleCan
Alabama
Posted: 05/07/19 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
RonRN18 wrote:
I am having issues with connecting and disconnecting the safety chain hooks to the hitch mount of my 2016 F150 truck. It is very difficult to get just the proper angle to get them hooked. The gauge of the steel of the hitch mount holes, the size of the holes and the thickness of the hooks makes this very difficult. Has anyone else had a similar issue? Is there some type of fix that is safe to make connecting and disconnecting the safety chains easier?
I put a couple of steel links in ours. They are a little longer, and easier to hook up.
CROSS YOUR CHAINS WHEN YOU TOW.
fdwt994
Indianapolis, IN
Posted: 05/14/19 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
D.E.Bishop wrote:
cavie wrote:
buy 2 Threaded carabiners/link extensions from you local Hardware store
X2. I installed the threaded chain links and applied some red loctite to the threads. Seems that folks like them and some are too cheap to pay $5 or so in the store. Now it's real easy to hook and unhook the safety catch hooks on my safety cables.
I saw these at the local home improvement store, but none that seemed to have the weight / strength capacity of the chain itself. I'm willing to bet some folks are attaching these type of chain links and instantly reducing the strength of their chain.
2018 F250 6.2 Crew Cab
2013 Palomino Solaire 307QBDSK
A family who loves to camp!
