RV.Net Open Roads Forum: Tech Issues: De winterizing
 > De winterizing
JimK-NY
NY
Posted: 04/29/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Here is what I have done so far this year:
added Timbrens to improve the ride and stop the sagging
added an upgraded battery charging system
cleaned inside
added an additional coat of ZEP outside
cycled the batteries and charged at 14.4 v.
When I get closer to using the rv, I will drain and bleach the water system. I also have 2 boxes of liquids and other stuff that will need to come up from the basement and stored in the rv.
swimmer_spe
Sudbury, Ontario, Canada
Posted: 04/29/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
schlep1967 wrote:
I do things a little different than you.
1. Go inside and open all faucets.
2. Go outside and open low point drains to get as much of the pink stuff as possible to drain out. Close low point drains.
3. As others have said, bleach. Hook up every hose you intend to use this year to your tank fill port (could be gravity or a hose connection) and pour bleach into the hose furthest from the camper. Now hook the hose up and fill the tank. This way everything gets some bleach to kill the bad stuff.
4. Pump bleach water through system to get the pink stuff cleaned out.
5. Turn off the pump. Close/open (depends how you look at it) the bypass for the water heater. Turn on pump to give a short flush of the water heater. Turn off pump and put plug in water heater. Turn on pump and open a hot water valve/faucet to fill the water heater with bleach water.
6. Let sit overnight. Next day. Repeat numbers 1 & 2 plus drain your holding tank and water heater.
7. When ready, fill with fresh water and enjoy.
This is a good list. The only issue I have is the draining of the pink goo on the ground. I would rather it in my holding tank.
JaxDad
Greater Toronto Area
Posted: 04/29/19 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
JaxDad wrote:
MudChucker wrote:
So... I think you are close, perhaps you are a bigger picture person and so have missed some details...
Leave hot water tank bypass in bypass configuration.
Partially fill fresh tank and dump a couple of times.
Fully fill fresh tank and ad a cup or 2 of unscented bleach.
Turn on water pump and pump mixture through all lines till pink stops pumping out.
Drink a beer.
Drain fresh tank.
Drink another beer while tank drains.
Fill fresh tank and pump through lines till bleachy water is gone.
Turn off pump
Done.
That the best reason why I like using air instead of that pink goo.
Besides, at my age I’m asleep after two beer.....
I am further north than you, so the goo is good.
It never gets cold enough for air to freeze and burst a pipe. LOL.
schlep1967
Harrisburg, PA
Posted: 04/29/19 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
The pink goo is biodegradable. If it wasn't, we wouldn't put it in a system we might drink out of.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
swimmer_spe
Posted: 04/30/19 01:01am Link  |  Quote  |  Print  |  Notify Moderator
Drink a beer.
Drain fresh tank.
Turn off pump
Done.
I am assuming you have never heard of a hydro lock. In our winters, that would become an ice cube. That ice cube could break a water line.
swimmer_spe
Posted: 04/30/19 01:03am Link  |  Quote  |  Print  |  Notify Moderator
I know it is biodegradable. However, that does not make it good to put on the ground where a local pet could drink it.
Besides, my holding tank is empty and putting it all in there is not an issue for me.
JaxDad
Posted: 04/30/19 05:37am Link  |  Quote  |  Print  |  Notify Moderator
Drink a beer.
Drain fresh tank.
Turn off pump
Done.
Yes, I know all too well what a hydrolock is, it’s when for instance, there is sufficient liquid in a cylinder to end the piston's stroke before it can reach TDC. Since liquids are nearly incompressible the piston cannot complete its travel and so either the engine must stop rotating or a mechanical failure must occur, or both.
I don’t understand what a locked up engine has to do with RV plumbing.
If you’re trying to imply that the liquid in the pipe would stop the air flow, no, it can’t do that. Not unless you have a tap shut and never open it during the blowing out process.
If you did that however, the same thing would occur using antifreeze too.
schlep1967
Harrisburg, PA
Posted: 04/30/19 05:49am Link  |  Quote  |  Print  |  Notify Moderator
JaxDad wrote:
Drink a beer.
Drain fresh tank.
Turn off pump
Done.
This argument has been hashed out many times on this forum. Lets just leave it at "Do what works for you" and move on.
schlep1967
Harrisburg, PA
Posted: 04/30/19 05:54am Link  |  Quote  |  Print  |  Notify Moderator
You could always put a bucket under the low point drains and save the pink stuff for next year. The problem with not draining the low points is there will be residual pink stuff in those drop down lines that will continue to mix with your fresh water for quite a while until it all works out of the system.
P.S. It would be harmless to any pets or wildlife. Just like it is to humans.
swimmer_spe
Posted: 04/30/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have one drain line and it is at the pump. I do not plan to reuse it. What I do is put fresh water into the fresh water tank. Turn pump on and start opening taps till no pink.
 > De winterizing
