RV.Net Open Roads Forum: Class A Motorhomes: Need a bit of 'educating'...
 > Need a bit of 'educating'...
georgelesley
Tennessee
Posted: 04/30/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
One more reason to use it is a bit more braking in a panic stop no matter where you are, that seems like a good idea. Don’t ask me how I know this.....
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
goufgators
Crawfordville, Florida
Posted: 04/30/19 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
goufgators wrote:
Need advice on when/where to use 'tow/haul'. Use only when ascending/descending hilly areas? Keep it off when on flat roadways? Exactly what does it do i.e. does it restrict the transmission from it's highest gear? Keep it on all the time when towing? Thanks!
Great info from all. Many thanks! Nothing like receiving a bit of free 'education'.
2017 Winnebago Sunstar (gas)
2005 Honda CRV Toad
Invisi-brake
goufgators
BarabooBob
Baraboo, WI
Posted: 04/30/19 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
What happened this time? Usually have at least one person say that they never use it. For me, if I have a trailer on the back, have a load on the truck, or I am in hill country, I am always in tow/haul.
Bob & Dawn Married 30 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
stripit
Prescott
Posted: 04/30/19 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
When you use the T/H button it will increase the engine rpm, on my rig it changes just under 600 rpm. I watched today to verify that it is locking out the 6th gear and will let the shift points go farther before any upshifts. When I'm rolling on what would be a flat I shift it off, to lower the rpm's. Any grades or hills, before I hit that incline, I shift it back on.
Stacey Frank
2018 Holiday Rambler Admiral XE 31A
SMI Braking system
08 Lexus 400H hybrid
2015 Cadillac SRX
1991 Avanti Convertible
T18skyguy
Eugene, OR
Posted: 04/30/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
georgelesley wrote:
G-Dad wrote:
A motor home is always “hauling”. Nothing wrong with using it all of the time.
I called the Ford RV hotline and asked their opinion. They agreed. Since most motorhomes are within 10% of max vehicle weight when loaded and also when towing, they recommend using it all the time. They also recommended schedule 2 (severe service) maintenance schedule.
One of our members has a transmission temperature gauge. He says when he's in tow haul the trans temperature is much lower, so he uses it all the time. I think that's a good idea. Lower trans temp usually means longer transmission life. I use it all the time and it's so nice, particularly if you need to slow down quick;tap the pedal drop a gear then repeat.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. 2017 Jayco Greyhawk 31FS. Wife and daughter. Three cats which we must obey.
dodge guy
Bartlett IL
Posted: 04/30/19 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
I had the 5 star tune in my V-10 Excursion with the 4 speed auto. it made a world of difference in how it towed the trailer. We now have a 2012 class A with the F53 V-10 and 5 speed auto. the tow haul is amazing in how well it handles the V-10 and the weight of the MH. I tried it with and without. without it shifted normally, but I was on flat ground in the Midwest. I was also 1500lbs less than what I would normally weigh and no toad. I`m sure I will always be using T/H. whether or not I want to get 5 star tune has yet to be determined. I`ll wait till I get some miles on it before I decide.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
