RV.Net Open Roads Forum: General RVing Issues: Cutitng Fiberglass
 > Cutitng Fiberglass
Fire19
Michigan
Posted: 05/02/19 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
I am ready to install a larger Hot Water heater in my 5th Wheel I have to open the hole in the Fiberglass by 4" on top and 4" on one side. What is the best way to cut the fiberglass without it chipping and cracking. This is on a 2002 Gulfstream Seahawk. Thanks
2000 Ford F-350 Dually Crew Cab
2002 Gulfstream Seahawk 29FKS
1998 GL1500SE
navegator
San Diego CA.
Posted: 05/02/19 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Use carbide blades on a scrollsaw unit, cut a bit smaller and then use a file to finish the cut, go slow and let the blade do the work if you push too hard you will chip the edges, going slow makes a cut that needs very little dressing.
navegator
RedRollingRoadblock
Oregon
Posted: 05/02/19 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Run some painters tape then cut through it. I will help reduce the possibility of chipping.
Got clearance? No frame or any thing in way?
beemerphile1
Ohio
Posted: 05/02/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Oscillating saw, pick one up at Harbor Freight cheap.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Z-Peller
Oceanside BC
Posted: 05/02/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Cut so blade teeth are going down thru gel coat side of material..scroll saw teeth will pull up thu material and chip gel coat. Put masking tape on gel coat side and cut with fine tooth saw pushing. Don't drag on the backstroke. Drill starter hole inboard of cut line if needed..
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
LarryJM
NoVa
Posted: 05/02/19 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Dremel either an abrasive fiber cut off wheel or a dremel mighty max with the 1/2 round cutoff blade. I would test first on a line inside where your final cut will be for practice and get some experience.
Larry
RAINKAP INSTALL////ETERNABOND INSTALL
Terryallan
Foothills NC
Posted: 05/02/19 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
Larry
Agree. Something without teeth would be best.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
2manytoyz
Central FL
Posted: 05/03/19 07:10am Link  |  Quote  |  Print  |  Notify Moderator
As already mentioned, an oscillating cutter. I used a cheap one from Harbor Freight to cut a fiberglass cover I made for an airpack (for work).
Link to the oscillating cutter: https://www.harborfreight.com/variable-speed-oscillating-multi-tool-63113.html
The tool itself works great, but I would suggest upgrading the blades if you plan on using it for more than a job or two. Here are the blades I'm now using: https://amzn.to/2DNsbge
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
ppine
Northern Nevada
Posted: 05/03/19 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I used to build fiberglass sail boats in WA state. One of the best tools is an air powered pizza cutter. A little round saw with 3 inch blade.
Jack Spratt
Maine
Posted: 05/03/19 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Abrasive grit blade in a reciprocating saw
Leprechaun 260 DSF
2017 Big Horn FL3750
'10 Yellow Lab to keep us on our toes.
