RV.Net Open Roads Forum: Class A Motorhomes: Fueling a gasser...
 > Fueling a gasser...
Vibrant93
Quiteville
Posted: 05/03/19 05:38am Link  |  Quote  |  Print  |  Notify Moderator
I tired the search but didn't come up with what I was looking for. Do any of you have issues when fueling your coaches with fuel? I have an '00 Suncruiser with the v10 and it takes forever to fill the tank with gas. If I'm at 1/4 tank it'll fill like normal up to about 3/4 tank and then it's a good 10 minutes to get the tank the rest of the way full. I literally have to keep clicking the nozzle handle as it doesn't want to take fuel. I'm assuming it's some sort of pressure/venting issue with the tank but I was more or less wondering if this is something common? The 1st couple of times out with the coach after we bought it I was only filling it 3/4 full and thought I had a fuel sending unit issue. After doing some mileage tests I realized we were never getting it full!
-2000 Itasca Suncruiser 35u
-2013 3,500lb trailer toad (www.trailertoad.com)
-1995 F250 Powerstroke (110,000 miles)
-1993 Mustang Cobra (11,000 original miles)
-1991 Mustang LX (race car, 10.20 @133.7)
2manytoyz
Central FL
Posted: 05/03/19 06:50am Link  |  Quote  |  Print  |  Notify Moderator
Never had that problem with either Class A I've owned, but did have that issue with a Jeep Wrangler.
In that case, the flexible fill hose, between the fill port, and the tank, has a tip over valve inside. It's a butterfly valve that's intended to shut the fuel hose off if the vehicle rolls over.
But mine was made of plastic, and eventually failed in the mostly closed position. Would only take fuel slowly, and kept "burping" gas. Major PITA.
I couldn't source the part from Chrysler, but someone on a forum found a direct replacement part from GM: https://amzn.to/2UZyJOK
The swap wasn't difficult and completely solved the issue. Good luck with your gremlin!
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
Dutch_12078
Winters south, summers north
Posted: 05/03/19 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Try checking the tank fill hose from underneath. There may be a dip in it that fills up as the tank fills, making the last 1/4 slow to accept fuel.
Dutch
2001 GBM Landau 34' Class A
10forty2
North Carolina
Posted: 05/03/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Yes, have had that problem since we purchased it, and the former owner said it was consistently a problem as well. My solution has been to lower the stabilizers on the fill side and jack up that side of the RV during filling, essentially making the fill angle more steep and less chance for the fuel to bubble back into the fill line, causing it to kick back off. Seems to be working well for me for the past few years. So far, no problems with doing that.....
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
the bear II
Torrance CA.
Posted: 05/03/19 09:39am Link  |  Quote  |  Print  |  Notify Moderator
On a truck I had I would have to turn the handle of the fuel nozzle up instead of down. This allowed me to fill the tank full at a faster rate.
Executive
Posted: 05/03/19 10:22am Link  |  Quote  |  Print  |  Notify Moderator
There is a vent tube that allows air to escape as the fuel fills the tank. This vent tube gets plugged since these coaches sit for awhile. Usually they're plugged by some insect that decided it'd be a nice place to call home. Find the vent tube, clean it and your problem will go away....we just don't fuel enough to keep that vent open, or we have too many bugs.....Dennis
BTW... you only need to post once. [emoticon]
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Ten Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
ItsyRV
Desert SW
Posted: 05/03/19 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue on my small Class C. The problem is in the design of the filler neck & tube. The easiest solution was to just turn the handle between 60 to 80 degrees sideways to the forward and that solved it. Can now fill up at the fastest setting without any issues. I could have done physical changes to the filler parts and system but so much easier to just tilt the nozzle.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
Matt_Colie
Southeast Michigan
Posted: 05/03/19 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Vibrant,
I have seen this problem a lot and even had it myself and managed to fix it.
Check two things:
Take apart what ever you have to so you can inspect the fill plumbing. It should have no pinches or dips in the run. Do what ever you have to do to fix those.
There is a small line that will most likely accompany the fill pipe, and this is a major headache. This line is called the "Fill Vent" and come off the top of the fuel tank to let the air out of the tank as it is filling. If it has any dips in it, those will collect wet fuel. Then filling the tank will blow those up to the fill neck and shut off the nozzle. Do what ever you have to do to make that line not dip.
I fixed this on both my coach and a friends (different manf.) My fueling time went from 45 minutes to 10 and really full. His is better but he won't say how much.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
4x4van
California
Posted: 05/03/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
As Matt said, check the vent line very closely. My last RV suddenly developed the problem; I would have to drive up on a leveling block to fill the tank it was so bad. Turned out that a mounting clamp for the vent line had come loose, allowing the vent line to sag, creating a dip in it. That dip filled with fuel, and would no longer "vent" while filling. Reattached the line to eliminate that dip, and the problem was solved.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
garyemunson
Reno, Nevada
Posted: 05/03/19 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
The fill and vent hoses are suspect. I'd check to be sure one or the other wasn't either cut a little too long or not pushed far enough onto the metal fittings causing a kink in the rubber hose.
