RV.Net Open Roads Forum: Fifth-Wheels: Camp site width?
 > Camp site width?
Rwake901
Central, Illinois
Posted: 05/03/19 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Any idea how wide the average camp site width is? I had no problems whatsoever backing our last two motorhomes and I’ve had three camping trailers with no problems but I suck backing this new fifth wheel. I need to practice someplace so I need to set up some cones and need to know how far apart to put them. I have the wide trailering mirrors on my truck and still can’t see worth a darn. lol Anybody else have backing issues when yours was new? Seems like there’s a delay and then all of a sudden it’s too late to correct it. Any tips would be appreciated. Thanks
rbrand
Victoria, BC, Canada
Posted: 05/03/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Once you get used to it. It is not a problem. I found that backing up the 29ft. Fifth wheel is a lot easier then my 7ft utility trailer.
The less you plan the more options you have.
Currently with a 26' Forest River Class "C"
Ex Navy Diver
Ex Archaeologist
Ex Museologist
Actively retired
wanderingaimlessly
SOBOVA
Posted: 05/03/19 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
What I was told when i first started with horse trailers was
when going forward, to wait until it seemed almost too late, and then turn hard.
Backing up, turn a little bit seemingly almost too early, and then watch for the trailer to react, and then follow it.
School parking lots on Sundays, maybe a large manufacturing facility, and use the lines to learn your rigs characteristics.
Campsites generally are less than 20 feet wide and that is using some of your sitting area.
Think about the ones you frequent, likely they only have about 4 feet extra on the drivers side and no more than 10 or so on the passenger side.
fj12ryder
Platte City, MO
Posted: 05/03/19 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
From my experience, there is no average. Sizes are all over the place. Put some cones out that are a couple feet wider than your trailer on both sides.
Howard and Peggy
"Don't Panic"
BB_TX
McKinney, Texas
Posted: 05/03/19 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
We have been in numerous sites where the pavement or gravel drive is not much more than 2-3’ on each side of the wheels. Get some cheap orange soccer practice cones at Walmart, go to an open parking lot ( I used a school parking lot on a weekend), and practice.
Dick_B
Palos Heights, IL USA
Posted: 05/03/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
12 feet ought to do it.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
philh
Belleville MI
Posted: 05/03/19 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Measure the width of the trailer, add 2 feet. Don't strive to be good enough, but be the best!
Durb
NW
Posted: 05/03/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
I feel your pain. I also could put my travel trailer wherever I wanted and have issues with the fiver. The biggest challenge is getting your cut line right. If you feel like it is wrong, pull forward and start over. Fifth wheels react slowly and there is seldom much room to correct in a campground. It is a good feeling when you know you have made it on the pad. Small corrections are simple when the truck and trailer are pretty much lined up. If you can back in 90 degrees to a 12 ft. road, you are in good shape.
Halmfamily
Munford, AL
Posted: 05/03/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Pulled farther forward than you think you should. When backing, as you've noticed, the turn starts slow then goes quick. Once you figure that out, with practice, it will become easier. I can back my 42' FW into tighter spots than my 8' cargo trailer.
Find a large parking lot and set up five gallon buckets 12' apart and practice backing. I have small orange cones I lay down for the path I want to follow when I'm by myself and backing into a tight spot
Good luck
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
 > Camp site width?
