RV.Net Open Roads Forum: Fifth-Wheels: Looking to buy older 5th wheel
 > Looking to buy older 5th wheel
Iamfreeatlast
Canton
Posted: 05/05/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I am looking into getting a 5th wheel that hasn’t been towed much in its lifetime. Should I be worried about this or look for a more active 5er?
MFL
Midwest
Posted: 05/05/19 11:53am Link  |  Quote  |  Print  |  Notify Moderator
You're not giving much info, but an older FW, that has mostly been parked, will likely need brake/bearing service, and tires. If it has been outside, with little care, and possible roof leaks, just walk away.
Jerry
Veebyes
Posted: 05/05/19 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Chances are that a well used one is a well maintained one.
2007 Alpenlite 34RLR
NMDriver2
New Mexico
Posted: 05/05/19 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
To many variables. Old and well maintained in the desert vs newer and parked near the ocean. Parked and only used a few months a year or parked and lived in all year. Driven 10K plus each year with no blow-outs or only 2K but with damaging blow outs. Each unit has to be looked at and evaluated for condition. Older and seldom used can be a red flag or a great bargain. No one can tell until they see the unit and go over it carefully.
Turret Class traveler
valhalla360
No paticular place.
Posted: 05/05/19 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
I'd rather have a frequently used model where the owner maintains it.
One that's sat on blocks for a few years likely needs:
- New tires.
- Repack and possibly new bearings
- Clean and adjust brakes and possibly other work.
- Do the running lights work...things corrode when not used.
Could easily be a couple grand extra in repairs to get her road worthy.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
dpgllg
South West Pennsylvania
Posted: 05/09/19 09:57am Link  |  Quote  |  Print  |  Notify Moderator
My 1st 5th wheel was a used unit that was parked at a permanent campsite. It was only a year old BUT I had to replace most of the clearance lights as well as the tail lights. The previous owners did not attempt to maintain the operational mechanics of the RV and as a result the lights were all corroded and had to be replaced. The tires were okay and the dealer serviced the brakes and hubs. Not sure what all was done. If this unit had sat for a longer period of time then I'm sure other issues would have come up.
A 5th wheel that has been used AND maintained to operate is a better option in my mind.
If your not sure of what to look for hire a RV mechanic to inspect the unit before purchase. This could save you many headaches and is worth the expense.
Dave
2013 2500HD Chevy LTZ 6.6 Diesel Ext Cab Long Bed
2017 Grand Design Reflection 27RL 5th Wheel
Dear Wife, plus three cocker spaniels
Fisher Bill
Tigard
Posted: 05/09/19 10:35am Link  |  Quote  |  Print  |  Notify Moderator
No matter the age best to look for dry rot in every corner, overhang, cabinet and underneath.
Of course a 15-20 year old rig will have 15 or 20 year old issues, everything has a life...
2006 Chevy 3500 Dually 6.6 Duramax Diesel & Allison Transmission
2010 Northshore 28RK by Dutchmen
Our first fifth wheel!!!
Iamfreeatlast
Canton
Posted: 05/09/19 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the great advice. I really appreciate your collective knowledge. You just saved me a bunch of money!
lenr
Indianapolis, IN
Posted: 05/09/19 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Most of the advice has been about running gear, but I honestly would be more concerned about caulking. A unit that has been sitting at a permanent site may have had little caulking or roof maintenance as the owners came to visit occasionally. The running gear is a given--it will need maintenance.
colliehauler
Mc Pherson KS USA
Posted: 05/09/19 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
^^^ This, I would be more concerned about maintenance of roof and caulking leading to water intrusion then whether it was parked or road use. Some people just don't give a darn, others are diligent about maintaining their investment.
