RV.Net Open Roads Forum: General RVing Issues: Various Rv types and wind
 > Various Rv types and wind
scbwr
North Ridgeville, OH
Posted: 05/06/19 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Just too many factors that affect how a rig handles in wind and semi push. I've owned two trailers, a 28' Sunline with a Hensley hitch (Dodge gas dually)and a 27' Winnebago Minnie with a 4 Point Equalizer (Toyota Tundra) hitch and both were very stable on the road, even in crosswinds. Our Bay Star does get some semi push, but does pretty well in cross winds. I've just added a steering stabilizer to help....haven't driven it on a long trip yet to evaluate its effectiveness. But, if there are high wind warnings, I'll keep it parked!
Trailers: It's about weight distribution in the trailer, quality of hitch and anti-sway system and size, wheelbase, etc. of the tow vehicle.
Fifth wheel: Seems that few folks have trouble unless they have an undersized truck. But...I have no experience with this category.
Class C and Class A: weight, wheelbase, weight distribution, tires, tire pressure, aftermarket gear to improve performance (Summo springs, stabilizer, shocks, track bars, CHF (cheap handling fix), and ??
And, I'm sure I've missed some factors....you could write a book on the topic!
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
Cobra21
minnesota
Our 21' Class C, short wheel base is also terrible in strong winds. We won't drive it in over 20 mph winds period! We had a 17' travel trailer prior with weight distributing hitch. The wind didn't phase this rig towed with a suburban. So yes, short class C's can be white knuckles all day long.
Brian
jplante4
Cape Cod
Posted: 05/06/19 06:25am Link  |  Quote  |  Print  |  Notify Moderator
Distance between the rear dualies is probably the most important factor.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 05/06/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
One of the best pieces of advice we ever got with our 28' Class C, was to load it up like we were going on a trip; and then get the wheels aligned. The original chassis is aligned with no weight on it. A loaded RV is thousands of pounds heavier, and it affects the suspension/steering.
After the alignment, our Class C endured many high-wind situations with a lowered level of vigilance on our part. I'm not saying it tracked like an arrow; but in 35 mph crosswinds in Wyoming, we didn't feel like we shouldn't be on the road.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 05/06/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Best TT I’ve ever pulled was a 31’ Airstream with a Suburban. Tag axle DPs are the best MHs...rock solid at 42,000+ lbs.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
BB_TX
McKinney, Texas
Posted: 05/06/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
I don’t think there is a pat answer to the question. I have towed our 35’ high profile 5er in high winds without realizing how high the winds were until we stopped and got out for a rest stop and had to lean into the wind to walk. And been behind MHs watching them “walk” back and forth when I barely felt any wind. But some say their 5ers and TTs do sway. And some say their MHs don’t. So the answer is “it all depends”.
myredracer
Langley B.C.
Posted: 05/06/19 08:50am Link  |  Quote  |  Print  |  Notify Moderator
winnietrey wrote:
OK, so 24ft class C, 15 years, 70 K miles all over the western US.
Things that come to mind: What condition are shocks in? Maybe upgrade to some heavy duty ones. Get alignment checked. Check front end for worn parts in steering like ball joints, track rod, steering box, etc. What tire pressure? Higher psi could help.
I would expect a class C to be much more stable while moving than a TT because of where the axles are positioned on a TT relative to the hitch. Each gust of strong wind wants to pivot a TT around the axle location and will strongly affect steering in the TV compared to a FW. A FW will feel fairly stable due to hitch being over the rear axle in a truck but being taller has more sidewall area and is more susceptible to being tipped over.
There is very little scientific study available on comparison of high wind & overturning vs. RV type. Wichita State university did a study for stationary (parked) RVs and found "minimum overturning wind speeds (perpendicular to the vehicle) of 24 m/s (53 mi/hr) for a 5.5 m travel trailer, 29 m/s (65 mi/hr) for a 9 m motor home, 33 m/s (73 mi/hr) for a 13,600 kg semi-trailer, and 45 m/s (101 mi/hr) for a 5 m camper van. ". No mention of a FW and the study did not address sidewall area of different RV types.
Towed on I-90 between Spokane & Seattle once in high gusting winds. Felt like driving on marbles and hard to stay centered in the lane even when slowed right down. A truck driver at a rest stop told us that even semis pull over in winds like that. Someone at a CG told us he has seen numerous FWs blown clear over there!
If it feels unsafe in high winds, slow way down or pull over for a while until the winds die down. Just because some idiots fly by you at insane speeds doesn't mean there's something wrong with your RV or you.
* This post was edited 05/06/19 08:57am by myredracer *
I hate CAPTCHA. It just will not go away...
Gil, Deb & Dougal the Springer Spaniel
2014 KZ Spree 262RKS, Reese DC WDH
2012 GMC Sierra 2500HD crew cab
ppine
Northern Nevada
Posted: 05/06/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
If I was bothered by 25 mph winds in Nevada, I would have to just stay home.
Driving a TC in a lot of wind is like being at sea.
I like driving a truck that weighs more than my TT. That helps a lot.
I had a pop up trailer and a hybrd trailer which were great in the wind. They just were not so good at the campsite.
* This post was edited 05/07/19 08:18am by ppine *
winnietrey
seattle
Posted: 05/06/19 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Shocks, tires, front end and alignment, all good.
I of course slow down, or pull off. My question is more in the vein of if it, is affecting me I would think it has to be affecting others.
Having never towed anything other than a boat, I was just curious, how the wind affected others.
I do tend to notice, most of the rigs, that scream by us, and do not slow down in the wind. Appear to be driven by younger drivers. No surprise there in my opinion
Jayco-noslide
Galesburg,Il., USA
Posted: 05/06/19 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Our 30 ft. Class C is bad and so is my son's 30 ft. A. You're going down the road in a big, flat, tall box. I guess our 25 ft. 5er was better but still not like a car.
Jayco-noslide
