RV.Net Open Roads Forum: Is a 13,000 BTU AC enough for a 22' trailer?
 > Is a 13,000 BTU AC enough for a 22' trailer?
wayfun
KY
Posted: 05/06/19 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
We are considering a Flagstaff Micro Lite 21ds. The standard AC is 13,000 btu? Is that adequate or should we upgrade to the 15,000 unit?
Thanks,
Dennis
MitchF150
Puyallup, WA
Posted: 05/06/19 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
How cold do you need it to be? I know you are in KY and I'm in WA, but I have been in 100+ heat and the AC will keep my trailer in my sig to whatever temp I want to keep it at, which is around 75, because any cooler just gets cold with the fan blowing on your body anyway.. I could get it to 68 if I wanted, but that's just too cold when it's 100 outside..
We don't have the humidity that you probably have either, so I guess I'm just talking out of my ass.... [emoticon]
If you have the option to get the 15k unit, just get it and adjust the temp as you please.. That's what I do with my 13k unit (that is over 16 years old now) and I have never had to turn the temp dial to max and the fan over LOW ever..
Good luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2003 Prowler Lynx 722F #5000 GVWR and weighs every bit of it! "> Happy Camping!
CincyGus
Cincinnati
Posted: 05/07/19 12:57am Link  |  Quote  |  Print  |  Notify Moderator
This is an easy one. How happy are you when your hotter than you wanna be? If you tolerate the heat well (along with all those that camp with you), save the money and use it for trips.
If Being hotter than you wanna be gets you cranky or ticks Momma off, You better write that check and get the 15K version pronto!
As always, It's better to Have it and not need it than to not have it and Need it!
2015 GMC 2500 Denali Crewcab 4x4
2019 Forest River Wolfpack 23pack15
Hope your travels are safe and the friendships made camping are lasting.
valhalla360
No paticular place.
Posted: 05/07/19 02:27am Link  |  Quote  |  Print  |  Notify Moderator
For a 22' trailer, 13k should be fine. Not a bad thing if the 15k is a cheap upgrade but certainly not critical.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Guy Roan
Posted: 05/07/19 04:29am Link  |  Quote  |  Print  |  Notify Moderator
The 13,000 is fine for that length, but if your trailer has a 50 amp service, (which I doubt), I would do it in a heart beat.
If your trailer only has a 30 amp service, don't do it. It could prevent you from running other electrical appliances at the same time it is running
Guy
cavie
Posted: 05/07/19 05:27am Link  |  Quote  |  Print  |  Notify Moderator
I have a 13 in my 2002 26' 5th wheel. Works just fine.
colliehauler
Mc Pherson KS USA
Posted: 05/07/19 05:48am Link  |  Quote  |  Print  |  Notify Moderator
I don't know if it is like a home unit in the fact if you go to large it doesn't run enough to take the humidity out of the air.
My 13,500 works well in my 35' seasonal up North by the Canadian border. If the same trailer was parked in the Southern US I would probably want two 13,500 units for that size trailer.
If the 22' trailer is insulated a 13,500 should do the job.
wayfun
KY
Posted: 05/07/19 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. Our last unit was a 36' trailer with dual AC units and 50 amp service. On really hot days we would use both units for the hottest part of the day. We do like to keep it cool, especially to sleep. I was hoping that a 22' unit could get by with a 13k unit.
Thanks,
Dennis
prichardson
Lafayette, La
Posted: 05/07/19 07:07am Link  |  Quote  |  Print  |  Notify Moderator
13500 is fine for that size. As colliehauler brought up if you oversize you don't get enough runtime for humidity control which is a big part of feeling comfortable. You will feel cooler at 75 degrees and 30 percent humidity than you will at 70 degrees and 60 percent humidity.
mbopp
Henrietta, NY, USA
Posted: 05/07/19 07:17am Link  |  Quote  |  Print  |  Notify Moderator
26' Heartland, 95 degrees, and the 13.5KBTU A/C handled it. But it really worked hard.
2017 Grand Design Imagine 2650RK
2012 F-150 XLT Ecoboost ("EcoBeast") supercab
Just DW & me......
