RV.Net Open Roads Forum: Travel Trailers: Tires for Shadow Cruiser 260BHS
 > Tires for Shadow Cruiser 260BHS
dwightr8
Lyndale, WA
Posted: 05/07/19 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Replacing the tires on our Shadow Cruiser 260BHS. Going to go with Goodyear Endurance. I'm thinking of upsizing from ST205/75R14 to ST215/75R14 to get a little extra load carrying capacity (gain 640#). I think the rims are 5.5" wide and there is plenty of clearance. Any problems?
Thanks,
* This post was edited 05/07/19 03:53pm by dwightr8 *
Dewey
Wife Terri, Golden Retriever Brandi
2015 Shadow Cruiser S-260BHS
2014 Ford F-150 3.5L V6 Ecoboost w/Max Tow
Equal-i-zerĀ® Hitch
librty02
Western Pa
Posted: 05/08/19 04:11am Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
I'd stick with the 205's the 215's will add to the diameter and you may get closer to bottoming out the trailer on the tire.
I assume you have load range C now is that right? If you want to upgrade load range just stick with the same size and go to load D but make sure your wheels can handle the extra 15psi per tire too.
2011 FORD F-150 FX4 CREW CAB ECO...
2018 Ford F-150 Max Tow Crew 6.5 3.5 Eco...
2013 Keystone Passport 2650BH, EQUAL-I-ZER 1K/10K
Lynnmor
Red Lion
Posted: 05/08/19 06:05am Link  |  Quote  |  Print  |  Notify Moderator
If the rims are indeed 5.5" then go for it. They both use the same air pressure and the diameter difference is very little.
dwightr8
Lyndale, WA
Posted: 05/08/19 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Good point on the extra 15psi. I hadn't thought about that. I'm trying to find out from Cruiser if it's a problem. I did find out my wheels are 5" instead of 5.5" so I will be staying with the 205's even though the diameter is the same for both.
Thanks
JIMNLIN
Oklahoma
Posted: 05/09/19 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Excellent choice.
26.1 vs 26.7 diameter ....or just over a 1/4" less space at the top of the wheel well to the top of the tire. Simply not enough to worry about.
I like a taller tire as it lets the vehicle ride a bit better. Going to a load D tire increases harsh ride ie; over RR tracks/potholes or just a rough road surface.
Now if I needed more load capacity in my tires to carry more weight then a load range uprate would be a good option.
rbpru
North Central Indiana
Posted: 05/09/19 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Increasing the tire load doesn't increase the axle rating. I switched to D rated tires after seven years on my C rated tires.
The new tires are rated C at 55 psi and D at 65 psi. I usually run about 60 psi to soften the ride.
A trip to the CAT scales when fully loaded for the road, showed the TT axle weight was only 5600#s on the 7000# axle pair rating.
Shortly after purchasing the new tires, I discovered that a rim bending road hazard or metal shard, does not care what the tire rating is or what they cost. [emoticon]
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
bob2194
Cache,Ok Gateway to the Wichita Wildlife Refuge
Posted: 05/10/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have a new cruiser Rv a different model. how did your tires hold up? If you don't mind telling what brad did they come from the factory. Just trying to decide if I should dump the factory tires. Thanks in advance.
20 year U.S Army veteran and still serving. Vehicle inspector (ARMY)
2018 Radiance 28QB pulled by 2018 F250 STX 6.2 Gasser
Equal-i-zer Hitch
eend
Alberta
Posted: 05/12/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
When we had got our Shadow cruiser they came with bias ply tires, and they were horrible, the trailer would just sway side to side, I put some Carlyle radials on an the trailer towed like a dream. and we put many miles on the unit, when I sold the trailer the tires still had atleast 50% tread left.
2014 Mazda CX5
2015 F150 ecoboost
1993 Airstream sovereign 21
1971 Boler 1300
dwightr8
Lyndale, WA
Posted: 05/12/19 10:31am Link  |  Quote  |  Print  |  Notify Moderator
These are tires that came on the trailer:
https://www.lionsheadtireandwheel.com/Vail-Sport-Radial-Tire
In doing some research into them, I think we got really lucky. We have had no problems in about 15,000 miles including a trip to Alaska and back via the Alaska Highway. If I had known then what I know now, I don't think I would have done that trip on them. Ignorance is bliss!
Good Luck,
Dewey
bob2194
Posted: 05/12/19 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply My trailer is a Radiance by Cruiser RV
I don't think those tires are on My trailer, but the ones on my trailer is also some strange name, I had never heard of. I only have 1200 miles on mine, and am not sure if I will keep them after the first year.
