RV.Net Open Roads Forum: CHF 2018 Thor, F53, Rear do I need Z brackets
 > CHF 2018 Thor, F53, Rear do I need Z brackets
BeaverCamper
Bend
Posted: 05/07/19 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
I just completed the CHF on the front of my 2018 Thor ACE 27.2 and as I am putting new Koni FSD shocks on thought I would do the CHF to the rear. However I have heard that I would need something called Z-brackets? Any comments?
Also what is the torque specs on the bolts when I do a CHF.
Thanks!
BeaverCamper (2019 Coachmen Leprechaun 260 DS)
MountainAir05
New Mexico
Posted: 05/07/19 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.youtube.com/watch?v=Rh1itgg398M
http://www.thorforums.com/forums/f27/chf-cheap-handling-fix-3377.html
Dale.Traveling
Newport News, VA
Posted: 05/08/19 04:36am Link  |  Quote  |  Print  |  Notify Moderator
There are two possible Z brackets you might have read about. First set are already there on the rear are already there but will need to be spun 180 degrees. A before image -
Second are as shown in the MountainAir05's second link. These are to return the setup to the original geometry and are optional. There are multiple ways to achieve the same result. Those that choose the option usually do both front and rear.
Regarding torque specs, I can't recall but 60 lbs and blue loctite sticks in my mind.
2006 Hurricane 31D built on a 2006 Ford F53
way2roll
Wilmington NC
Posted: 05/08/19 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Just flip the existing ones.
georgelesley
Tennessee
Posted: 05/08/19 07:55am Link  |  Quote  |  Print  |  Notify Moderator
We have all been using 66 lbs of torque with blue locktite. Don’t forget to check the sway bar bracket bolts as well, many of us from seemingly all years have been finding them loose on the rear. Remove and use blue locktite as well retorque to 66 lbs. our 2014 with 10,000 miles were loose and falling out when I did them three years ago.. since then no problems although I do check them once a year.
i did our CHF front and rear separately and could notice a substantial difference in handling after doing each end.
There is a guy who makes excellent brackets specifically for the CHF and they allow a variety of user settings. He can be found on IRV2. You may also consider a rear trac bar, it also made a huge difference in our 2014 F-53.
George & Lesley
2014 Itasca Sunova 33C, 2019 Jeep Cherokee Lattitude Plus toad, Demco/SMI towing system
BeaverCamper
Bend
Posted: 05/08/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice. I do already have a aftermarket sway bar and track bar. I also already did the front CHF.
Thanks again!
drumcorpschamp
Southeast PA
Posted: 05/12/19 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
CHF? Please define.
Jerry
* This post was edited 05/12/19 05:01pm by drumcorpschamp *
RedRollingRoadblock
Oregon
Posted: 05/12/19 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
Cheap Handling Fix Found on a competing RV website so you best do a search for it.
Reference the above picture it is a DIY job moving the downlinks to the inter hole effectually shorting the sway bar to give better sway control.
