RV.Net Open Roads Forum: 24 ft Class C with full wall slide
 > 24 ft Class C with full wall slide
bobndot
Posted: 05/09/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Re slides in class c's and class A's .
The A's might be using hydraulic slides and the A's might have a little more beef in the framework of the coach where the slide slides. The headers on A's might have more room above the slide to build a more beefy header. That might be the reason the A's coaches seem to have less issues, especially flexing.
Remember not move a coach once you deploy a slide. I have seen people pull into sites and deploy the slide then find out they are too far away from the pedestal and move the coach back n forth to get closer and then level it...all with the slide hanging out . That's a good way to crack your sidewalls of your coach as well as possibly bind the slide it the frame.
Bea PA
Waynesboro, PA, USA
Posted: 05/14/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Following this thread, we had HWH on both our gas and diesel Class A MH, did not go with a slide on this one because I was afraid of the gear system, learned a lot here and will look at Winnies with the Lippert, unless I hear bad news on them. Thx for all the info
Bea PA
Down sized Winnebago 2012 24V Class C
2003 Gold Wing 1800 recently triked (Big Red)
