RV.Net Open Roads Forum: Class C Motorhomes: Freshwater tank question
 > Freshwater tank question
Jayco25E
PA
Posted: 05/08/19 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I own a travel trailer and my sister in law just bought a 2019 Thor C-Class 28Z and since the dealer did not bother to explain how everything works I was asked to do so. Not a big deal as I am a long time camper but for the life of me I can not figure out where or how the freshwater tank drains. On my TT it just drains out on the ground. Does a C-Class drain into the gray tank? And is so any ideas on where the valve might be?
Thanks for any help.
2008 Chevy Avalanche
2005 Jayco 25E HTT
1 kid (but always end up with a full camper)
2 retired Greyhounds
Bumpyroad
Virginia
Posted: 05/08/19 10:27am Link  |  Quote  |  Print  |  Notify Moderator
no on the grey water tank.
there should be a pipe from the FW tank at a low location and valve/cap on that.
bumpy
Old-Biscuit
Verde Valley
Posted: 05/08/19 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Fresh water tank 40 gallons
Grey tank 32 gallons
Black tank 26 gallons
Fresh water tank would not drain into either waste tank
Contact Thor and inquire
Customer Service (877) 855-2867
wildtoad
Blythewood, SC
Posted: 05/08/19 11:33am Link  |  Quote  |  Print  |  Notify Moderator
There should be a section in her owners manual (if it came with one) that says where it is. But it would not drain into one of the holding tanks. Check in the storage bays underneath the water tank and you should find a valve.
Tom Wilds
Blythewood, SC
jgellis586
Cheboygan, MI
Posted: 05/08/19 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same rv except i s a 2017. The fresh water drain is on the drivers side towards the back of the rv. It is a small spigot that runs to open and let the water drain.
bobndot
Posted: 05/08/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that many TT's FWT is strapped and exposed under the TT while a MH's FWT is often mounted inside supported by the floor. A longer tube is involved and could be run anywhere where they have room for a clean run to the ground. My class C tube ties into the low point drain cold line below my chassis but the petcock is inside a storage compartment.
Sometimes they hide a drain petcock inside a baggage compartment behind a trap door . I have a hinged trap door inside the compartment where the water pump is housed as well as the winterizing valve (pick up tube) . Some rv's also have the fresh water drain petcock in that location .
Other places are below the fridge , there might be a removable panel screwed in place or under the bed near the tank itself.
Jayco25E
PA
Posted: 05/09/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Thanks I will look in that area again.
Jayco25E
PA
Posted: 05/09/19 06:17am Link  |  Quote  |  Print  |  Notify Moderator
I did notice what looked like a removable panel under the fridge. Which is about the location above the freshwater tank. I will check there for the water pump. Thanks
way2roll
Wilmington NC
Posted: 05/09/19 07:04am Link  |  Quote  |  Print  |  Notify Moderator
The low point drain for the fresh water should be a small line with a valve somewhere under the RV or near the FW pump. But, since this is new RV a simple call to Thor and they will email you the plumbing schematics that show where the LPD is.
AJR
Close to Madison Wisconsin
Posted: 05/09/19 07:15am Link  |  Quote  |  Print  |  Notify Moderator
My older 28A had the fresh water drain spigot on the driver’s side. It was below the other outside water connections.
2014 Leprechaun 290QB Chevy 6.0
2015 GMC Terrain AWD
